Old 09-08-2010, 03:20 PM   #1
remist17
remist17's Avatar
Engine Photos - help needed
Hi all. Can you post up some engine photos of V8's. I am swapping out a 6 for a 383 stroker. I am not sure how the heater lines, EGR, fuel and cooling lines are run to the 80's engines.
any help is appreciated. I am running a Edelbrock air gap intake, holley 670 avenger.
2013 Chevy Silverado, Z71, 5.3L, 4 door
2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40
Support the Troops.
remist17 is offline   Reply With Quote
Old 09-08-2010, 04:18 PM   #2
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Re: Engine Photos - help needed
hope this helps....
I do have some carb pix too, if you want, just let me know.... 4 BBL Q-jet
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 09-08-2010, 05:14 PM   #3
nbpro
http://67-72chevytrucks.com/vboard/s...ad.php?t=65484
nbpro is offline   Reply With Quote
Old 09-12-2010, 02:50 PM   #4
remist17
remist17's Avatar
thanks...
I posted another thread but can anyone help me out with mounter mount brakets
I am swapping out a V6 for a V8 in my 1987 R10. I knew the mounts are different so I went to a you pull it and found a 86 that had the 8 cyl brakets. It had a utilty body so I am assuming it was at least a 3/4 ton truck. Came home and the brakets are not even close to matching up to the holes in the frame.
My questions:
1- Is there a difference between 1/2 ton and 3/4 ton engine brakets?
2- Is there mounting holes in the frame for a 8 cyl or do I have to drill
3- Is there a difference between 4x4 and 2x4 brakets?
(the brakets in question are the ones that mount to the frame and cross member)
What am I doing wrong !
Please help!!!
Support the Troops.
