09-10-2010, 06:50 AM | #1 | |
Conversion Truck Addicted
MPH and KPH Speedos
i would like to convert my speedo to KPH as thats what we use here
im thinking of if i just swap the gauge it self with a KPH would this work what about the Cruise Control stuff? do i need to get a Buffer for a KPH one (Green Model)? what about the modual it self do i need to change that?
Thomas Quote:
09-10-2010, 07:58 AM | #2 |
great southern land
Re: MPH and KPH Speedos
im wondering the same, an where would i get a kph speedo?
rod 86 chevy c10 silverado |
09-10-2010, 07:59 AM | #3 | |
canadian trucks has them
Thomas Quote:
09-10-2010, 09:10 AM | #4 |
Still plays with trucks
What about one of the dual range ones? Would that work for you?
I believe all the speedos that are 85 mph are also marked for KPH. I think the year range is 1980-89 for mechanical speedos.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
09-10-2010, 10:18 AM | #5 |
18 Till I Die
I found this one in a 88-91 burb.(didnt check the year really) It has the trip meter in the speedo which I like. I think it should be a simple direct swap. Nothing else should be a problem
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... Last edited by kelsfine69; 09-10-2010 at 10:20 AM. |
09-10-2010, 11:47 AM | #6 | ||
kelsfine69 thats the one i mean
Thomas Quote:
09-10-2010, 12:00 PM | #7 |
I made an overlay for mine that got rid of the kph markings and changed the range from 85 mph to 90 mph. You could do the same with kph instead.
09-10-2010, 12:01 PM | #8 |
It is pre-1990 as the speedometer is mechanical. 90 & 91 are electronic and are sought after by people doing LSx swaps.
09-10-2010, 02:22 PM | #9 |
great southern land
yes, i need one in kmh, that is electronic as im doing an LSx..... do the speedos from 90-91 fit the 80`s dash bezel without much modification?
09-10-2010, 02:26 PM | #10 | |
It is the bezels & dash pads that need to be matched together for proper fit. I forget the year break but the squared dash pad has a different contour around the bezel than the older rounded dash pad so there is a gap to deal with if you mix & match.
