Old 09-11-2010, 09:20 AM   #5
solidaxel
solidaxel's Avatar
Re: softer suspention for AD trucks
Thanks for the info.
Every time I look at his ad in the mag. there is a caption that says "rears coming soon !"
What you are telling me as soon is now !!
I set up my truck waiting for his rear springs to be on the market thanks for the report.
The next time you are under your truck would you take a measurment of your drive shaft length from center of "U" joint to "U" joint and if you could the distance from the center bolt on the spring to the rear eye on the rear shackle. Does it use the same shackles and bolts on the front and rear? Did you use the same shock location as the stock 54?
What size tires are you running on the rear?
It would be nice to see a pic of the side view, and thanks for your help
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
