Old 09-05-2010, 12:38 AM   #451
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
well got a frame today
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-05-2010, 08:19 AM   #452
baclay9
Re: my 80 build
I am doing the same thing you are right now, swapping frames. It doesn't seem too bad so far. I know this is snowball stuff but do yourself a favor and go ahead and put new bushings, ball joints, ect in it while you are this far down. No since in doing it again later. Of course if this is your DD you may not be able to have it down that long. Looks good man. Have fun with it.
baclay9 is offline   Reply With Quote
Old 09-05-2010, 11:29 AM   #453
flamingbig10
6.0 powered square
Re: my 80 build
Four years ago when I started working on my truck I replaced all the bushing and steering components, so I will be using them on the new frame, and yes this is my daily I will be able to borrow my grand pa's jeep wile its down
Aaron
Old 09-06-2010, 01:08 AM   #454
flamingbig10
6.0 powered square
Re: my 80 build
Cleaned up the frame today
Aaron
Old 09-06-2010, 08:18 AM   #455
v502
v502's Avatar
Re: my 80 build
LOoking good man.
v502 is offline   Reply With Quote
Old 09-06-2010, 07:03 PM   #456
menace121978
menace121978's Avatar
Re: my 80 build
oh yea!! going to do her up right!! nice job Aaron!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-06-2010, 11:16 PM   #457
flamingbig10
6.0 powered square
Re: my 80 build
yep I have a different perspective on quality of work now since I work at a top notch auto repair shop, if it wasn't done right the first or dressed up it will be this time.
I did get a little work done today a was able to cut the rivets off for the factory tail pipe hanger, but I still have the rear bump stop brackets to cut off, the cross member that holds the disc brake valve has a loose rivet so I may cut all the rivets out and replace with bolts
Aaron
Old 09-11-2010, 08:00 PM   #458
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 09-11-2010, 10:44 PM   #459
flamingbig10
6.0 powered square
Re: my 80 build
I got the rear end unbolted so tomorrow I'll move the frame to the back yard and start stripping the paint I plan on have frame sanded and painted by the end of the month
Aaron
Old 09-11-2010, 11:26 PM   #460
SCOTI
SCOTI's Avatar
Re: my 80 build
I think I noticed that frame on C-list. Smart way to get the swb rails & get it all slicked/painted w/o down time on the truck.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-11-2010, 11:28 PM   #461
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
man i thought im the only one with a messy garage lol
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-12-2010, 11:46 AM   #462
JohnC
JohnC's Avatar
Re: my 80 build
Nice score on the frame man. Like Scoti mentioned that's a good way to go about it. Keep us updated.
JohnC is offline   Reply With Quote
Old 09-12-2010, 12:07 PM   #463
flamingbig10
6.0 powered square
Re: my 80 build
It was on Craigslist for a couple of months
Aaron
Old 09-12-2010, 12:07 PM   #464
flamingbig10
6.0 powered square
Re: my 80 build
its mostly my parents stuff
Aaron
Old 09-12-2010, 07:02 PM   #465
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 09-13-2010, 12:36 AM   #466
flamingbig10
6.0 powered square
Re: my 80 build
moved the frame to back yard and started on removing the rear bump stop brackets, then I still need to weld on washer to the front left shock mount since its wallered out
Aaron
Old 09-13-2010, 09:20 AM   #467
JohnC
JohnC's Avatar
Re: my 80 build
Just my opinion, but I don't think those wheels will look good on your truck.
Looking good man, keep it up!
Old 09-13-2010, 09:39 AM   #468
flamingbig10
6.0 powered square
Re: my 80 build
there chrome plated though
Aaron
Old 09-14-2010, 10:24 AM   #469
bakerboys
bakerboys's Avatar
Re: my 80 build
I have a question for you my shortbed sits kind of high i have 8 leafs on my leaf springs my sons longbed only has 4 leafs should i take out some leafs
or just replace them
bakerboys is offline   Reply With Quote
Old 09-14-2010, 10:36 AM   #470
SCOTI
SCOTI's Avatar
Re: my 80 build
At your current drop, I would just swap on some shock relocators up front vs. the washer idea. Measure your shocks & see if it's a good idea.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-14-2010, 08:19 PM   #471
flamingbig10
6.0 powered square
Re: my 80 build
if you still want your towing capacity go with some drop shackles
Aaron
Old 09-14-2010, 08:20 PM   #472
flamingbig10
6.0 powered square
Re: my 80 build
I look in to it
Aaron
Old 09-14-2010, 08:24 PM   #473
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 09-14-2010, 10:14 PM   #474
draggin86
draggin86's Avatar
Re: my 80 build
man you are making some good progress!
draggin86 is offline   Reply With Quote
Old 09-14-2010, 11:22 PM   #475
flamingbig10
6.0 powered square
Re: my 80 build
thanks
Aaron
