09-11-2010, 10:32 PM | #1 |
One of these days.......
? lift spindals for 84 3/4 ton ?
Does any one know if any company makes lift spindals for square body 3/4 ton.
09-12-2010, 12:19 AM | #2 |
Re: ? lift spindals for 84 3/4 ton ?
Fab Tech once upon a time for 1/2 ton stuff. Haven't seen anything since. Might try a search on Fab Tech.... maybe you'll come across some used stuff.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-12-2010 at 12:20 AM. |
09-12-2010, 10:45 AM | #3 |
Fabtech only made a 3 inch "A" arm lift for the 73-87 1/2 ton trucks. I have seen 3/4 ton trucks where they have installed this lift and modified them to accept the 3/4 or 1 ton ball joints and then bolt up the 8 lug spindles.
There are posts on this site where someone has adapted the 1/2 ton 88 and up lifted spindles. however, Fabetch does offer an 8 lug 4.5 inch lifted spindle for the 92-99 chevy trucks. I don't know if anyone has had any luck fitting these spindles to the older trucks.
www.cardomain.com/id/pooz911 |
09-13-2010, 02:50 PM | #4 |
Active Member
The fabtech 73-87 1/2 ton lift kits can be adapted to the 3/4 ton. you will need to replace the ball joints in the kit with 3/4 ton ball joints.
Danny Nix CPP (Fabtech Motorsports years ago) |
09-14-2010, 02:48 PM | #5 |
Thanks,,, how hard is the 73-87 1/2 ton kit to adapt to 3/4 ton? where can I find the kit. heres a pic of the project,,,it sits just right now, but when I put motor in it will set it down some.
09-14-2010, 07:50 PM | #6 |
