dropping my 67
I have a friend who lowered his 72 with 2 1/2" springs all around..and without changing shocks....is this ok to do???? i am wanting to lower my 67 with little cost involved but i refuse to cut or alter my springs.....please let me know what you think....also...can i just change my springs in the front and use lowering blocks in the back????thank you all..
#2 | |
Happy to be here
![]() Join Date: Mar 2000
Re: dropping my 67
The best method is new springs and new shocks. If you can't afford that, there is no reason why you can't cut the front coil until you can afoord to do it right. Cut is fine, heating is bad.
Re: dropping my 67
^^ Cutting in moderation is fine. One coil yeilds 2-3" of drop; don't go beyond that amount.
![]() Join Date: Dec 2009
Re: dropping my 67
What about a 67 using Jeep spring in the back with new shocks is that possible on a tight budget?
Re: dropping my 67
Define tight budget? Depending on how the drop is done, OE replacement shocks are more than acceptable & should fit within a 'tight' budget.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-14-2010 at 12:09 AM. |
Re: dropping my 67
I wanna cut front spring and put TJ Jeep springs in rear with KYB springs possible without new panhard bar in rear and safe to drive?
Re: dropping my 67
1-coil off the front, Jeep springs in the back & KYB GR-2's would be a decent combo.
Re: dropping my 67
ok sounds very do able! What about the bar in the rear can I do without till I can get a nice kit from ECE or can get the correct adjustable bar? Thanks for info Scoti
Re: dropping my 67
I've seen them heated & then 'bent' to re-center the rear. On my 67 (back in the day), we cut one end of the Panhard bar & shortened it to the required length. I've learned alot since then & wouldn't shorten one regardless of budget. I would just do a budget long Panhard bar & make my own mounts & such.
Re: dropping my 67
I would just do a budget long Panhard bar & make my own mounts & such. Can you give some more details here please?
#11 | |
Re: dropping my 67
You can also just stretch the OE bar but you need to make sure the length is right before welding it up.
