Old 09-16-2010, 09:23 AM   #1
C10Slim
Re: C10Slim's 66 Build Thread
Originally Posted by apachedaddy View Post
Could you give me some info on your steering column and wheel. Part numbers/IDIDIT??/dealer/ is it a retro fix column? Was looking at the IDIDIT colums from summit and wanted to see if there others out there that may be cheaper is all. Thanks for any info you might have for me.
It is an IDIDIT column retro fit series 1140657020 (column shift). The wheel, hub and horn button are Billet Specialties classic series.
I found the cheapest price on the column was Performance Online, they also had a 20% off moving sale going on at the time, so I really got a deal.
C10Slim is offline   Reply With Quote
Old 10-12-2010, 08:59 PM   #2
C10Slim
Almost done wiring! All the underhood wiring is complete. This flex-a-lite fan controller is awesome. Runs 2 stage will start a 40% and then ramp up to 100% as you reach temp. Also let the can run for 30 seconds after you shut it down. We also got everything in the dash wired up and the gauge panel mounted. We took the wiring through the driver side inner fender/wheel well and it worked out great. All we have left is to install the grille, headlights, parking lights and trim and the wiring will finally be complete! I also have a glass guy coming this weekend to install the front and rear glass. She is so close to being road worthy I can almost taste it!
Old 10-12-2010, 09:04 PM   #3
C10Slim
Few more...
Old 10-12-2010, 09:25 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
Nice work Slim........lookin' good.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 10-13-2010, 12:45 AM   #5
Dinos63
chevy only
Dinos63's Avatar
slick!! i am diggin the gauges
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 01-05-2011, 10:04 PM   #6
C10Slim
Painted the bed wood this weekend with KBS rust seal and blacktop gloss top coat. It turned out great looks like black glass. I just need to put the new polished bolt set in.
