Post Your 4-Link or 3-Link Setups!!
I need some ideas folks.....
Re: Post Your 4-Link or 3-Link Setups!!
Anybody?
![]() Join Date: Dec 2008
Man I was bent on fabbing my own setup & by the time I added it all up I was close enough to SD's price so I just ordered their kit,it saved me alot of time & effort
67GMC Slammed
here is mine.. I'm not gonna lie, I have stolen ideas from vaious other members
my dropmembered 67 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383215 |
67cheby
![]() Join Date: Sep 2008
mine , a little Porterbuilt, a little Suicide doors, a little Mayhew race cars , a little KP components all rolled into one
Junior Member
Thanks guys.
My question for those with the 3-link and trailing arms: Did you install trailing arms just for the bags (mounts)? If not why would you run both? |
planet, I'm not sure I understand your question,but I'll take a shot at it.
The susp. systems that are posted all require lower bars to keep the axle from twisting because all the mounts at the axle 3 or 4 link/ upper or lower, pivot.This keeps the pinion angle pretty consistent thru the suspension cycle,unlike the factory trailing arms wich are fixed to the axle.The only real diff. between 4 & 3 links is the upper wishbone allows you to eliminate the track bar & still keep the axle centered side to side.The bags are mounted on the lower arms mainly for convenience.Hope this helps , Mac |
Most people mount the bags on the lower bars for the canti-lever effect, meaning more lift out of the bag.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
Thanks fellas.
Is there any reason to keep the leaf-spring setup if running bags?
Happy to be here
![]() Join Date: Mar 2000
Sure there is. If your not planning on going really low and you don't want to cut the bed, a "Air over Leaf" system will do the job just fine.
