Need help with front roters
I have a 68 stepside with a 86 Corvette IRS out back with disc brakes. My problem is I have 71 C-10 drop spindles in front . Are they a roter out there that will fit these spindles that has the small bolt pattern lugs to match the Vette IRS. Hope someone has ran into this before that can offer some advise
Re: Need help with front roters
You might want to look at rotors for 69-70 Chevy full-size cars and 69-82 Corvettes. These two are similar but not identical. The Corvette parts will probably be easier to find because the Chevy discs were optional, not standard. However, the Corvette rotors come less hubs, so you will need the hubs too.
Ray |
I am a Referee of life.
Or just have a machine shop drill your rotors.They should be able to space the bolt pattern you want between what you have.Just make sure to keep the pads taken care of since a new rotor will mean machine work again.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
raycow;I thank those year full size chevys have the same lug pattern as the 71&up trucks.
Pol sells rotors for a 71 chevy 1.25inch rotor with a 4.75 pattern like the vette just watch the hub bore when you buy rims
70 SWB STEPSIDE 70 BLAZER 09 challenger |
PanelDeland;I have considered redrilling my org. roters but was hoping I could fined one that would fit right over my spindles. But thers a lot of facters diameter,bearing size,redrilling may be my only option, thanks for your input.
OARNGESI; Iam not familar with Pol
pol= performance online www.performanceonline.com
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
#9 | |
69-70 full size are the only 4-3/4" rotors (besides C-3 Corvettes) that take the same bearings as the trucks. Ray |
Old Skool Club
![]() Join Date: Jun 2001
GM has had the 5 on 5 pattern, as raycow stated. It used to be Cadillac, Olds, Buick and Pontiac had it, and Chevy didn't. I have a pair of old adapters that let you run a 4 3/4 on a 5 on 5 hub, or vice-versa, so you didn't have to run two spares. These are old.....like back in the late 5o's or early 60's. Back then, running an Olds rear end in your '55 Chevy race car was not unusual. I don't think these adapters would have you wanting to run them on the rear end, but who am I to say how they were used?
When the Chevies came out with disc brakes on the '71 trucks, I'm sure some bean counter at GM said to cut parts inventory and share some of the stuff across the parts lines. As to how many of those parts are shared....I don't know. Re-drilling makes sense, but it isn't what I like to do unless I'm real good friends with the machinist.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
![]() Join Date: Apr 2000
I dont know if you still can but if you go to the AC Delco web site with a part # it would give you a list of everything it fit.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
