Telescoping steering column?
Is it possible to push my existing stock column further in towards the dash? I'm ok with the angle, but I just want to push it further towards the dash. I looked at the bottom of the column at the floor board and I noticed some tabs at the very bottom of the column. Is this possible?
BMW & ASE Master Certified
Re: Telescoping steering column?
Ive done just that. you need a welder, cutt off wheel, drill, drill bit and a second column to dash bracket.... maybe even 2 plastic rivet if you feel like it. I'm 6'6" and I can sit with my arm almost strait... gained an extra 2".... didnt even have to get a percription
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#3 | |
All About the BOWTIE
great trucks, but seems that people musta been smaller and shorter in the 80's?.. IMO.. designers didn't give much for big and tall guys with these trucks.... ![]() put in a tilt column... which helped me some... but used the stock steering wheel.. might have to grab me a smaller one..
CaliDude76 ![]() "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 09-17-2010 at 12:50 AM. |
crew cab fixes all your problems.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
I am in the same boat. I am looking to hopefully gain 2" of room in the steering column myself. I called ididit, inc today and they recommended their 9 bolt shorty steering wheel adapter. That adapter will give you 2" more. Has anyone done that and was successful??? Are there any custom steering columns available??? I have am 87 with tilt and the windshield wiper/cruise control stem.
Hmmmmmmmm..........I wonder if I can make a Cadillac tilt/Tele column fit....I'm already wanting to add an airbag and steering wheel controls from a Monte Carlo though......
Jay 2001 Pontiac Aztek GT |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
You actually dont have to cut and weld anything. I took all the dolts that hold the column in place (under dash and under hood) and was able to push my column in considerably. Made a HUGE diffrence. I'm 6'6" and need all the room I can get. Probably why I also have a crew cab>
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Can one of you guys that have done this take some pics of what you did and post them up. I need some more belly room and 2" would make a huge difference.....(Thats what she said)
About two years ago i went to a local swap meet and there was a guy selling steering columns and he said he had some that he had shorten like 2 or 3 inches i dont remember exactly, for like 100 bucks so im sure it is possible.
Just loosen the bolts that hold the dash to under the dash. Then under the hood there is a strap with a bolt through it that also holds the column. Loosen that too and get in the truck and push in on your column. Mine slid right down. Very easy and well worth 15 minutes work.
So it doesnt affect the shift linkages negatively?
I'm 6'2 in a regular cab with bucket seats and non tilt column so this would help a good bit. that and maybe a smaller steering wheel later on. |
#12 | |
I was thinkin the same thing about the linkage.. I replaced my column with a tilt.. and can't see how the linkage would slide any...
CaliDude76 ![]() "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 09-17-2010 at 12:31 PM. |
You know,.. another possibility that could save room for us big guys...(Besides a crew cab..lol).. is getting a bench seat with thinner foam padding...
I noticed (my bench anyway),.. that it has thick padding on the back part, and the seat part... I've seen some that weren't so thick. Like maybe a bench from like a 90's Silverado.. those were a lot thinner,.. and weren't that uncomfortable...
CaliDude76 ![]() "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... Last edited by CaliDude76; 09-17-2010 at 12:34 PM. |
#14 | |
Could I just hammer those tabs in and move the harness? Also, did it affect your shift linkage...like others are asking? Here are pics of what 1972SuperCheyenne is referring to about the "strap with a bolt through it that also hold the column" under the hood. It's located under the hood where the column first comes out through the firewall. Last edited by HumbleChevyBuddy; 09-17-2010 at 02:04 PM. Reason: Added photos... |
#15 |
That is the one under the hood I was talking about.. However, my truck has a 6.0/4l80e with a Lokar shift linkage so I was able to adjust it. But when I had the 350 and stock shift linkage I was able to tweak it just a tiny bit and get it to work perfectly.
#16 |
Addicted to Rust
![]() Join Date: Dec 2009
The Knuckle and housings from one of the 84 ish front wheel drive caddys would most likely bolt on. All of the telescoping parts are above the plate that you have to tighten up if the tilt is wobbly. The early ones from the seventies were hard to get parts for several years ago when I had on that needed some work. Grant makes an adapter for a wheel. Corvette parts would probably work but they come with a premium price. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
#17 |
you can loosen the 2 bolts on the firewall/engine bay side, loosen up the 2 bolts holding the column to the support bracket and slide it maybe.... maybe 1" and then the park/neutral switch on the lower portion of the column will hit the firewall (interior side).
ah, I still have the pictures, excellent.. I didnt take a picture of the stock column, but I'm sure you can imagine it... anyway, you have the park neutral switch toward the lower end of the column, you also have a notch in the inner tube aswell. see pictures. ![]() ![]() you have to make the square hole on the inner tube before welding the outer pieces together or you will have no park neutral switch.... ![]() as far as the intermediate shaft.... put that sucker on the wire wheel and you will see the glue filled holes (2). Take a drill bit and drill it out.. super easy to drill since its glue. Now you can adjust its length shorter. make your new marks and trim if desired to retain stock like length on the inner shaft. DO NOT PUT BOLTS to hold the 2 shafts together, you can use plastic rivets... or fill it in with some hard glue. it needs to break easily if you get in a nasty accident. obviously. anyway thats what I did and it worked for me. clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 09-17-2010 at 08:32 PM. |
#18 | |
#19 |
Any suggestions on where to get a smaller steering wheel? I am very hesitant on doing any cutting on the steering column.
#20 |
well there are perks of having a smaller steering wheel ya know.. you can drive your car with hand cuffs on .. lol
clint
#21 |
Does anyone have any updates on how this is being done?
#22 |
I had a step by step picture how to.. ? Can't see the pictures?
#23 |
I've seen a 78 Caddy telescopic column work in a truck and I saw a 68 Caddy telescopic in a 72 Chevy truck. Its amazing how well you can cross breed GM parts.
#24 |
Parts and more parts
I have used several different smaller steering wheels in my time, but found that the aftermarket billet wheels suchbas the Lecarra brand is the best to mount and takes the least amount of pain to accomplish. Many of the cheaper ones tend to install in a complicated fashion and some of them have a foam outer wheel ring that deteriorates soon after you start using it. I buy mine through Yogi's Street Rod parts.
As for pushing the steering column into the floor further, you can loosen the two bolts on the clamp at the firewall, loosen the two nuts on the dash bracket and pushin this will gain some more room. If you want to go further, the part that runs up into the column from the steering box will have to be modified some to get it to go down further, and you will have to look at your bolts under the dsh to let the column slide further. As for the shift llinkage, it will move with the column, you may have to loosen the setscrew on the shift linkage rod and move it slightly, but I doubt it. That screw is down low in front of the firewall and is easy to get to. You may also have to adjust the string clip for the tranny indicator needle. it is just a slide on pinch clip and that should be easy.
Frank |
#25 |
Well, I did do the tilt/tele mod to my S10 Blazer and will do it to my 1989 GMC Sierra as I love it!
![]() ![]() ![]() I will be having the 'Vette wheel recovered next year. From the pivot pins down is S10, pivot pins up is Cadillac Deville and a Corvette steering wheel with an S10 horn button to make it look all factory original. Cost: $45. $10 for the wheel with horn cap and $35 for the column.
Jay 2001 Pontiac Aztek GT Last edited by c10sport; 10-15-2013 at 01:18 AM. |
