Old member
Do as I did and just block off the second outlet on the difusser tube behind the glove box and tape the center drivers side off. It does the same thing and only cost a couple of peices of masking tape and some card board.
You can also use a paper towel roll and cut it to over lap the openings and tape it down good. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
| Bookmarks |
| Tags |
| 72 gmc, a/c, central vent |
