Closed Thread
Old 09-16-2010, 02:18 AM   #1826
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Re: What did you do to your truck today?
Originally Posted by losthope View Post
lol its not satin black its rustolem black primer rattle can ! but am planning on painting it john deer blitz black after i do some of the body work it needs! like i painted my 54 ford sedan it gives you that primerd/satin look but is real paint but is illegal to use in california but i got a gallon left to paint the truck! i also love the satin black look
Every one of my paint jobs has been Rustoleum rattle cans, I've just used the satin black instead of the primer. Check out my build thread (in sig), there is a pretty good shot of the Camaro in there on the first page. 16 cans of satin black, and 5 cans of satin white, some striping tape, and two weekends worth of work (5 years ago). Either way bro, your pickup looks good! BTW, why would that john deere paint be illegal in Ca?...oh wait, it must work really well.
fryer1979 is offline
Old 09-16-2010, 05:26 PM   #1827
markeb01
Senior Enthusiast
markeb01's Avatar
From what I’ve experienced there isn’t all that much difference between Rustoleum and John Deere Blitz Black, particularly if applied with spray equipment. They are both synthetic enamels and have similar properties. My first Rustoleum job was rattle can flat black on a 49 Plymouth back in the 70’s:
It turned out great considering it was painted outside in a dirt driveway.
When I first built my truck the original hood was damaged so I painted it Rustoleum flat black (with spray equipment) while continuing to look for a replacement. After several years of North Idaho weather it showed no signs of deterioration. Here’s what it looked like when first painted:
After a decade of abuse most of the shiny lacquer was shot, and since nothing can go over lacquer except more lacquer or unhardened enamel, I started searching for paint. After reading the following thread many times (along with tons of others) the Blitz Black sounded like the way to go:
http://www.crankshaftcoalition.com/w...tz_Black_paint
Fortunately I live in a state where this can still be purchased, but finding it isn’t much easier. Here’s what it looked like a year ago, and the paint remains virtually unchanged today:
The key to having the finish come out with the desired sheen using either brand of paint is to experiment with the type, ratio, and speed of the thinner. Acetone dries so fast the results look like primer, and tiger stripes easily. I tried a variety of normal, fast, and slow acrylic enamel reducers, and tested each on a spare panel. Once the preferred mix was decided on, it cannot be altered throughout the paint job or it will come out looking considerably different on the various panels. With rattle cans it’s just a matter of trying to get uniform coverage with enough volume to lay flat without striping.
markeb01 is offline
Old 09-16-2010, 11:05 PM   #1828
narx66gmc
i painted some bits and pieces...
Build Thread - Papa's truck build up
narx66gmc is offline
Old 09-17-2010, 12:21 AM   #1829
sams60gmc
sams60gmc's Avatar
Today I spent an hour and a half getting my old bushings out of 1 lower control arm. Hopefully I'll be able to get the other one done tomorrow.
My goal is rolling chassis by the end of the weekend!
Was thinking about taking it to Rat Rod O Rama to show off my frame but it says no trailers!!
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 09-17-2010, 05:49 PM   #1830
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
What if we push it in to the show?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 09-17-2010, 08:11 PM   #1831
knuckledragger
knuckledragger's Avatar
Pulled the front suspension out of the 78 donor.That is all.
knuckledragger is offline
Old 09-18-2010, 01:24 AM   #1832
sams60gmc
sams60gmc's Avatar
lets do it! I think it would be sweet to have a frame laying on the ground.
Old 09-18-2010, 01:39 AM   #1833
sams60gmc
sams60gmc's Avatar
Well today I had alot to do I want to get my truck to a roller by Sunday. I started off by taking the one cross shaft out of my lower control arm and tried cleaning up the threads I messed up. First side went good. Second side the die nut went crooked and screwed up the threads. So I started calling the junk yards. Only place I could find cross shafts was a junk yard in town that wouldn't seperate from the arms and they wanted 70 bucks for the pair.
So I threw an ad up on Craigslist WTB cross shafts, and within twenty minutes I had an email so I called the guy and he told me 20 bucks for the pair of A arms.
I ran out there on my lunch break.
Then after work I cut my old cross shaft out of my other A arm and cut the A arms away from the cross shafts of the arms I just bought, made them way easier to take apart.
I had a check list of everything I wanted to get done before I left work and I managed to get it all done, including packing bearings, and machining new thick washers for my lowers.
I've got one side almost all buttoned up and hope to have the other side on early tomorrow, then I'll roll her outside and see how it looks with that fresh paint and new tube A arms.
Old 09-18-2010, 01:02 PM   #1834
rasanders22
Nothing. I am broke. My dog needed a 150 dollar vet visit because his ear is filled with blood.
rasanders22 is offline
Old 09-18-2010, 01:54 PM   #1835
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: What did you do to your truck today?
Bought some Tail Lights today so I can mount them temporarly on my frame of my bed while I'll have the bed off.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Old 09-18-2010, 09:34 PM   #1836
sams60gmc
sams60gmc's Avatar
Got the front end of my truck all back together for now. And made this video, just messing around like the 80000 dollar can crusher the MEGA SLAB
Old 09-19-2010, 12:05 AM   #1837
narx66gmc
bought a paint and rust remover wheel for the drill and two cans of paint. more pics tomorrow.
Old 09-19-2010, 03:41 PM   #1838
lakeroadster
Started mocking up tail pipes, routing them outside the frame rails. More details in my build thread..
lakeroadster is offline
Old 09-19-2010, 05:49 PM   #1839
knuckledragger
Took a wire brush and 2 cans of ez off to the donor front suspension .Looks good!
Old 09-19-2010, 05:55 PM   #1840
losthope
losthope's Avatar
bondo cracks ,primerd,painted, and installed 1962 chevy bel air steerting wheel! and i had a 6x9 speaker in a box i had in garage that fit right under the bench seat!
losthope is offline
Old 09-19-2010, 06:14 PM   #1841
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
New tach install here.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 09-19-2010, 06:18 PM   #1842
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Rear Parking Brake Levers, never should have cleaned up around the truck BEFORE doing the brake job. On the hunt now for replacement levers.
aerotruk63 is offline
Old 09-19-2010, 06:25 PM   #1843
Rusteeze64GB
Drove my truck 10 miles for the first day after getting the truck registered. Slow moving thats for sure. Need to get the rear end rebuilt, cant go faster than 50 miles an hour. Here it is in my new front yard after the drive and a wash.
Rusteeze64GB is offline
Old 09-19-2010, 06:44 PM   #1844
sams60gmc
sams60gmc's Avatar
Nice work.
Old 09-19-2010, 07:05 PM   #1845
glendale
glendale's Avatar
installed new heads and got mine back on the road.
glendale is offline
Old 09-19-2010, 08:27 PM   #1846
willyp
willyp's Avatar
Finished connecting the wiring on the ididit column to the painless harness, reinstalled the tach and my new mooneyes wheel then hooked up the horn. I love it when everything works the first time, had time for a cruise before the game.
The price of cool aint cheap.
willyp is offline
Old 09-19-2010, 09:39 PM   #1847
LinkbeltOE
Repaired my core support and both inner fenders so they could be sand blasted and powder caoted flat black along with my hood hinges.
LinkbeltOE is offline
Old 09-19-2010, 11:53 PM   #1848
narx66gmc
sanded and painted two wheels dark dark gray. started stripping the chrome and rust from the grill for its paint this week.
Old 09-21-2010, 08:28 PM   #1849
losthope
losthope's Avatar
not much changed the oil again on the new motor,fixed the fuel that was dripping from the hose at the fuel filter!thats about it....
losthope is offline
Old 09-21-2010, 09:07 PM   #1850
1939fiat
1939fiat's Avatar
I drove mine full of junk to a swap meet ..
going to tow our race car on a road trip Sunday..
BTW,anyone remember where the thread is regarding replacing lower steering shaft bearing?
thanks;
Rick
1939fiat is offline
Closed Thread
