Old 09-17-2010, 08:47 AM   #1
RandyP
Getting Old; Going Broke
RandyP's Avatar
TBI to Carb
So I have a line on a decent little 87 SWB truck. Has a 305 with TBI, but has had an electrical fire that went from engine bay to dash area. Was more of a melt down than actual fire, but most the wire looms are trashed as is all the plastic connections etc.
I can get 85 and down LWB trucks all the time for ~200 or so with no drive train or with engines locked up. My question is, and I know it's possible because I see them advertised all the time, can you get an intake that will fit the 87's 305 block but is made for carb setup? Seems you can literally just remove all the ECM and TBI wires, put an older vacuum advance distributor in and rewire with stuff from an 85 or so down, correct? I'm guessing probably have to change the sending units in the gas tank(s) and put a fuel pump on the block, otherwise seems like fairly easy swap.
Thinking I can get this truck cheap and drag a parts truck in cheap and maybe only have to buy a few items depending on what the parts truck really has. Might luck out and get a parts truck with just a locked up motor and be able to use the fuel pump and distributor and such from it as well. The intake has me wondering though since I know the 87 engines have a somewhat different bolt design than the older stuff. Hoping I'm not looking at swapping heads as well, but I guess that might be doable as well.
I also have a wire loom from a TBI truck, as well as the ECM and stuff, so that is always a thought as well. But putting it back to a carb setup might be simpler and cheaper in the long run since basically anything with a plastic connection on the end of the wire also got damaged it seems.
Surely someone has went from TBI to carb on here.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 09-19-2010, 02:08 AM   #2
joe231
joe231's Avatar
Re: TBI to Carb
TTT
For ya Randy
I believe all you would need to do is open up the center holes on your carb intake like you had to do to run the TBI intake with older heads....
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-19-2010, 03:21 AM   #3
MTCK
MTCK's Avatar
Re: TBI to Carb
http://www.summitracing.com/parts/ED...ET&prefilter=1
That ought to get a carb on there but I think you'll need to stick with the electric fuel tank and get a pressure regulator.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-19-2010, 10:44 AM   #4
joe231
joe231's Avatar
Re: TBI to Carb
good thinking,
there is probably not a hole in that block for the furl pump push-rod
CHEVY ONLY
Old 09-19-2010, 11:06 AM   #5
RandyP
RandyP's Avatar
Re: TBI to Carb
Had not thought of there not being a place for the mechanical fuel pump. I'll have to look. I'm supposed to get another phone call to go look closer. Basically like 3 trucks for one price sorta thing, only one with drive line though is 'smoked' perse.
Old 09-19-2010, 11:14 AM   #6
joe231
joe231's Avatar
Re: TBI to Carb
there should be a place to bolt it up, but chances are the holes aren't tapped and the hole for the push rod isn't there either.
right on, you can give that trailer a workout
CHEVY ONLY
Old 09-19-2010, 11:31 AM   #7
RandyP
RandyP's Avatar
Re: TBI to Carb
Now I am remembering I never went and bought any chains, straps or comealongs. Might be a trip to Atwoods as well this morning, lol.
I got a few bucks horded back, and can either buy this gaggle of trucks (two will go to the crusher rather quickly) or I got a line on a late 70's suburban. Supposed to have a big block in it with only about 25k on it. Just waiting on phone calls to come look. But if it is for some reason a 1/2 ton suburban with a big block, I might have to change my plans.
Then again, I can't even put a valve cover on without it leaking to high heaven. I should maybe rethink my plans even further.
Old 09-19-2010, 11:34 AM   #8
joe231
joe231's Avatar
Re: TBI to Carb
CHEVY ONLY
Old 09-19-2010, 12:23 PM   #9
68 TT
Still plays with trucks
68 TT's Avatar
Re: TBI to Carb
Originally Posted by joe231 View Post
good thinking,
My TBI block is not drilled for the fuel pump push rod and only has one of the four cover plate bolt holes drilled.
I thought about making a drill fixture using another block to be able to drill the TBI block out so I could run a mechanical fuel pump on it if needed.
You would need a pretty long drill bit and it would have to be exactly the right size so the push rod fit right and got the proper amount of oil like stock. Probably a job best left to an engine machine shop.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
