Old 09-15-2010, 02:31 PM   #751
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: "Rice Rocket'
The bolts are all tight, should I loosen/retighten em all?
#1 was at tdc idk what stroke, it seemed to start idle good and rotor was at #1.
Compression stroke is when it pushes your finger off sparkplug hole right?
And do I NEED an adj. vac. adv.?
John
1999 Toyota Tacoma 4x4
Old 09-15-2010, 05:11 PM   #752
sourkraut
sourkraut's Avatar
Re: "Rice Rocket'
check the gaskets on the headers/manifold if they are blown out or cracked.
yes, when it pops you finger off.
you are plugging your vacuum advance line going to your dist. when setting the timing right?
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 09-15-2010, 06:07 PM   #753
oldblue1968chevy
Re: "Rice Rocket'
Yes pluggin the vac.line going to dizzy and I was supposed to have been plugging the vacumn port on the carberator too (which i wasnt doing, so i hope thats why I was getting a false reading?..)
They are new dounuts, but I didnt tighten it up all evenly, I ran 1 nut down, then the next, then next then tightened em all up good
my mom is picking up a msd cap/rotor for me THANK YOU MOMMY lol
John
Old 09-15-2010, 08:02 PM   #754
oldblue1968chevy
Re: "Rice Rocket'
New cap/rotor
Carberator after rebuild (still need to put the side linkage on, anyone got a pic of edelbrock 600 left side pic)
Still need to do some adjustments on the outside of it.
And I need to get my motor back at TDC #1 Compression stroke
Can i bump the motor over with no dizzy? (No oil pumping oil)
John
Old 09-15-2010, 08:05 PM   #755
67chevy1series
67chevy1series's Avatar
Re: "Rice Rocket'
nice work
67chevy1series is offline   Reply With Quote
Old 09-15-2010, 08:12 PM   #756
rustaddict
Re: "Rice Rocket'
How big is your cam? This is gonna sound like a silly question but are you positive that both of your marks are lined up exactly right on your timing chain set?
71 Cheyenne
55 Chevy hardtop
53 Farmall Super A
92 Chevy Silverado daily driver (284k on the original clutch and still counting)
rustaddict is offline   Reply With Quote
Old 09-15-2010, 08:44 PM   #757
oldblue1968chevy
Re: "Rice Rocket'
the dots, yes i was paying attention still at that point (drove 1 hr north of me to assemble my bottom end with the machinest who was an older guy maybe 50s/.60s)
The top sprocket dot was at the bottom, the lil sprocket at the bottom the dot was at the top
Anyone know if I can bump the motor over with no dizzy, is that ok/safe?
John
Old 09-15-2010, 10:22 PM   #758
Charles Hettich
Re: "Rice Rocket'
i hope that thing gets runnin good!
Charles Hettich is offline   Reply With Quote
Old 09-15-2010, 11:24 PM   #759
rustaddict
Re: "Rice Rocket'
Yep, you can bump it over with the distributor out
71 Cheyenne
55 Chevy hardtop
53 Farmall Super A
Old 09-16-2010, 08:36 PM   #760
oldblue1968chevy
Re: "Rice Rocket'
So far not so good, anyhow ima get it sometime, ive got a 3 day weekend...
John
Old 09-16-2010, 10:03 PM   #761
Charles Hettich
Re: "Rice Rocket'
once you get it runnin right (which i have faith that you will) youll hafta post a video. i wanna hear that thing idle!!!!!
Old 09-16-2010, 10:14 PM   #762
oldblue1968chevy
Re: "Rice Rocket'
im glad you have faith in me lol!
it sounds WICKED at idle
John
Old 09-16-2010, 10:17 PM   #763
Charles Hettich
Re: "Rice Rocket'
thumpr cam right?
Old 09-16-2010, 10:45 PM   #764
oldblue1968chevy
Re: "Rice Rocket'
yessir!
ill try to get a vid. morrow for ya if u tell me how to make it get on here
John
Old 09-16-2010, 10:52 PM   #765
Charles Hettich
Re: "Rice Rocket'
hahah welll someone else will hafta help ya with that one
Old 09-17-2010, 05:06 PM   #766
oldblue1968chevy
Re: "Rice Rocket'
ok the shaft in the dizzy was stuck with grease dirt and the springs wernt flingin lol
tomorow:
pull bed and work on gas filler/vent
springs/check timing
new plug wires/looms
finish carberator/install tune
i got a bad burn on my finger from exhaust...owch
oh i did a few small burnouts....this thing doesnt have the power it should have still though..it does run much berrer though
John
Old 09-17-2010, 05:07 PM   #767
oldblue1968chevy
Re: "Rice Rocket'
http://temp.corvetteforum.net/c3/joe..._Recurve.shtml
John
Old 09-17-2010, 06:57 PM   #768
Hubscrub
Cruzin
Hubscrub's Avatar
Re: "Rice Rocket'
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 09-18-2010, 08:11 PM   #769
Hubscrub
Cruzin
Hubscrub's Avatar
Re: "Rice Rocket'
Well im eating cracker barrel n manchester if your truck was runnin good i could buy ur dinner
Proverbs 3:5,6
Old 09-19-2010, 12:05 AM   #770
67chevy1series
Re: "Rice Rocket'
hey cool can i join
Old 09-19-2010, 12:10 AM   #771
oldblue1968chevy
Re: "Rice Rocket'
awww gee, not this weekend, maybe next, ya take a raincheck lol?
I had to pull the bed to cut some more off the braces, i couldnt fill the truck up caused it leaked and it was a bad design, so i spent 2.5 hrs cutting with pliers, hammer chizel grinder sawsall cutoff wheel (my gf dad did it the 1st time with torch, SO much easier lol) i'll try to get pictures after church morrow...
u drive your truck to manchester this evening? i think they have a cruise in pretty soon or maybe tonite it was idk lol
John
Old 09-19-2010, 09:03 AM   #772
Hubscrub
Cruzin
Hubscrub's Avatar
Re: "Rice Rocket'
^no i drove my daily driver we was just cruisin around
Proverbs 3:5,6
Old 09-19-2010, 05:29 PM   #773
armyavncowgirl
C10 Junkie
armyavncowgirl's Avatar
Re: "Rice Rocket'
you make me miss my projects
your project has come a long ways! I'm very impressed. Sad about the accident but then again, things happen for a reason.......helped with the funding of the restore
will continue to watch your thread, as I now head out in search of another project lol.
09 Chevrolet HHR --- Cruck --- cross between a Car and a Truck
Former rides:
1967 C10 LWB
1972 C10 LWB
1969 C10 LWB (parts truck)
armyavncowgirl is offline   Reply With Quote
Old 09-19-2010, 05:50 PM   #774
oldblue1968chevy
Re: "Rice Rocket'
Yeah, I cant wait till its back on the road im really gettin tired to working on it constantly..
Ive still gotta get the timing crap set right, get my 600 edelbrock on (finished, anyone have a side pic of edelbrock manual choke carbertor?). And do a gas filler for my blazer tank, ive got one in the floor now but it leaks etc and is a crappy idea..ugh. I pulled the 69-72 trim off today i guess i'll throw it in the barn and save it for another truck if i ever finish this one..Im thinkin bout spray bombin my orange bed blue to match the truck lol...idk I may roll it out and wash it and get pics idk..im searchin for blazer tank fillers now, thinkin thru the backup light..but will have to somehow trim inside stakepocker
John
Old 09-19-2010, 06:23 PM   #775
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: "Rice Rocket'
You might try Edelbrock's website.
Keith
Convert to disc brakes.
