Old 06-09-2003, 12:19 AM   #51
Project1970
14.1 @ 96MPH
Project1970's Avatar
FWIW, we've ran synth in several vehicles since they were new and never had an oil-leakage problem with the sole exception of IIRC one of the intake seals on the '94 Z28, and that was a massive TSB in itself (along with the unbalanced driveshaft!). The '97 Suburban had 95,000 on the clock without a single oil problem (transmission, suspension and cooling were all a different story, though!), the '94 Z28 doesn't have any oil problems (though it requires 15w50 when running synth) after 85,000, and the '97 E320 (75,000mi) and '02 TrailBlazer (12,000mi) require it specifically!
Every one of those has run it since new, too...whenever I get the money for a new engine (sheesh, new bottom end and new A/C... ) I'll also be switching over to either 0w30 or 5w30 Mobil1...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 06-09-2003, 12:39 AM   #52
Low69CST
68burb, Sorry bud, I didn't mean to be attacking you, the only one thing I was responding to from your posts was the thing about the corvette recomending Mobil 1. I see that as more of a marketing scheme rather than chevrolet being so impressed with a motor oil they decide to spend money on banners for each corvette they sell recomending it. I ddin't see anything in your posts about getting people to switch oils. However, in other peoples posts i saw people discussing synthetics and their thoughts. So, i included my thoughts. The leak thing may be a myth, i was mearly stating my thoughts on the situation. sorry man.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
