09-15-2010, 07:13 PM | #1 |
Chance
67-72 Steering Shaft All The Same??
Is the steering shaft that connects the column to the steering gear box the same for all 67-72? Is the new one in LMC any good? The one on my 1968 rattles every time I hit a bump. I was in the junk yard last week and I noticed the column on a 1970 had a different looking steering shaft from the one on my 1968. If that is the case is the 1968, 1970, or LMC shaft more reliable? Thanks!
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
09-15-2010, 07:50 PM | #2 |
Re: 67-72 Steering Shaft All The Same??
I'm thinking there was a telescoping and a non-telescoping shaft. Don't know what year it changed though.
Ray |
09-15-2010, 07:58 PM | #3 |
67-68 had a non-telescoping solid shaft in the column. In 1969 the shaft was made in two pieces with the lower piece set up to collapse in the event of a frontal crash. The shafts are the same 69-72. The 69-72 columns and shafts will interchange with the 67-68 setups.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
09-15-2010, 09:18 PM | #4 |
My LMC catalog does not show a steering coupling shaft for sale???
The Truck Shop catalog shows a 3/4" and a 13/16" one, both labeled 67-72 for $109. Those dimensions are for the splined shaft that comes out of the column and goes into the coupling clamp.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
09-20-2010, 01:12 PM | #5 |
Not sure if you solved your problems, but i just rebuilt a good steering column from three donor columns. So i have alot of spare "3 on the tree" steering column parts that need a good home.
If anyone needs them send me a PM. |
