Old 09-20-2010, 08:54 PM   #1
tim21391
tim21391's Avatar
is it worth it?
i have a 402 in my truck.. rebuilt probably 5-7 years ago.. it runs fine now.. but i have had to replace gaskets here and there.. so my question is.. would it be worth it if i pulled it. check the cylinder wear if its still good and pistons are still good give them a good parts wash bath. install bearings and new cam and lifters and gaskets and everything? my idea.. im sure its got carbon build up and get one of the summits rebuild kits for like 400 bucks and hopefully give it a few miles per gallon this way? or shall i just leave it and wait til a major problem occurs.. take about half tank to drive 60 miles
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 09-20-2010, 08:58 PM   #2
fine69
fine69's Avatar
Re: is it worth it?
Use the old adage, DON'T FIX IT IF IT AIN'T BROKE.
If it runs fine why mess with it?
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 09-20-2010, 09:00 PM   #3
tim21391
tim21391's Avatar
Re: is it worth it?
just seein if by cleaning the stuff would get me better mpg.. i want a different cam tho. i want a bigger one to give me the more loping sound
Old 09-20-2010, 09:06 PM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: is it worth it?
doing some tuning would probably give you more of a boost in MPG than doing a rebuild. What carb are you running and how is it jetted? What ignition are you running? These both can be tuned to optimize mileage.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 09-20-2010, 09:08 PM   #5
Jacfourteen
Re: is it worth it?
Also forgot to ask what tranny and rear are you running? OD and/or taller gears could help out too.
Old 09-20-2010, 09:11 PM   #6
71swb4x4
71swb4x4's Avatar
Re: is it worth it?
The $400 you spend would take a long time to make up in whatever fuel economy you did find. Not to mention that it will cost you WAY more than $400. We all konw what happens when you pull an engine to do a quick "refresher". One thing leads to another and pretty soon you are spending $2,000 trying to save $500 in gas.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-20-2010, 09:38 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: is it worth it?
If you want a "lopey" cam... you can forget good MPG...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
