Old 06-08-2003, 03:23 PM   #1
bigjimzlll
bigjimzlll's Avatar
will headers for a K10 fit a C10?
I was given a set of headman hedders for a K10..part number 69230. they have a little better clearance for my angle plugs..anyone ever use K10 headers on a C10?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 06-08-2003, 03:51 PM   #2
72MARIO
72MARIO's Avatar
I think that they will tuck up in the frame rails un like the 2wd headders that sit below the frame rails. They should fit. I think....
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-08-2003, 05:28 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
I'm pretty sure heddman truck headers fit any chevy P/U, 2wd or 4wd, as long as its SBC powered from 67-87. Might want to check your Jeg's catalog to make sure.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 06-08-2003, 10:48 PM   #4
bigjimzlll
bigjimzlll's Avatar
ttt
Anderson,CA
Old 06-09-2003, 07:55 AM   #5
Dean
Dean's Avatar
I installed a set of headers from a C20 on a K20 so they most likely will work. They were a brand called JR whatever that is....
Dean is offline   Reply With Quote
Old 06-09-2003, 08:34 AM   #6
Mike C
Mike C's Avatar
Depends on the header, but most likely they will not. Unless you have the 2 wheel drive V8 mounted in the 6 cylinder postion. But it really does depend on the header. A GOOD header, meaning one that was designed for a 67-72 whether automatic or manual that fits without modifying the OEM clutch linkage most likely will NOT fit, but a header that fits the 73 and up K series probably will.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-09-2003, 08:36 AM   #7
tom hand
CCRider
tom hand's Avatar
You should have no problems with an automatic...if it is a stick you may run into interference with the z-bar
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-09-2003, 01:57 PM   #8
kaarazy
headers
I used 2wd Dynomax headers on my K20 and just used the threaded rod from the Z-bar to clutch fork from a 2wd and bent it around the header tube. 20,000 miles and no problems.
1972 K/20
355 c.i.d.
sleeper "Circus Wagon"
kaarazy is offline   Reply With Quote
