Closed Thread
Old 09-22-2010, 07:25 PM   #876
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: What did you do to your truck today!
Wahed it..well after I pulled the trany pan put in a filter kit changed the modulator on the trans and painted the pan...swapped the 3 core rad for the 4 after I added a return for the heater hose...plumbed up the heater ....and then I put a set of points and wires in the Cady motor twisted the key to make sure it was still runnig well...and hell yea it shifts like a million $$$ and got rid of that small stumble on the bottom...stay tuned saturday is speed runs @ the air port..wish I had a bottle kit for it..
I think its about as good as its going to get...but dont we all want a bit more!!!
Hottrucks is offline
Old 09-22-2010, 08:54 PM   #877
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Removed Front Bumper Sent To Chromer and the Rear One i Got From DPassmore NOS Parts Are So Sweet. Put AXtra Bumper i had on And lost one Bumper Bolt....
4 Lights Are Better Then 2
1971 GMC SHORTY is offline
Old 09-22-2010, 09:56 PM   #878
barry h.
barry h.'s Avatar
Originally Posted by deatonk67 View Post
i put a new master cylinder on my truck( O reilly makes junk parts) then repainted my wheel well... good day sence it had a lifetime warranty on the master cylinder
ithought i might give you some insight on oreilly parts,I run a auto repair shop in Arlington,Tx and i buy about 10,000.00 per mounth in parts and i have less warranty issues with them than my other suppliers but some times it happens,however i aways buy new not reman.hope that gives you some insight.
barry h. is offline
Old 09-22-2010, 10:13 PM   #879
vectorit
What?
vectorit's Avatar
Chased an electrical bug, and still haven't found it.
Came to terms that the T case needs to be completely resealed. $$$$$
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 09-22-2010, 10:54 PM   #880
67chevy1series
67chevy1series's Avatar
well i installed my newly aqquired 67 bed
67chevy1series is offline
Old 09-22-2010, 11:03 PM   #881
bovey
bovey's Avatar
Finished installing my large hump. Hush Matted everything an started to reinstall stuff.
Looks like new. Very happy.
bovey is offline
Old 09-22-2010, 11:07 PM   #882
C10NEWGUY
Put some eastwood tank tone on my fuel tank.
1977 Chevy C10 RWD long bed
C10NEWGUY is offline
Old 09-23-2010, 02:06 AM   #883
powerbench
powerbench's Avatar
Got my cam in and put my heads on and torqued everything...and sanded the chrome two piece timing cover to paint it....
powerbench is offline
Old 09-23-2010, 03:39 AM   #884
anchors
Hmmm let me see installed a tach then promptly blew the freaking motor that is only about 200 miles old, blew chunks of the piston on #5 cylinder right out the side of the block. Hmmmmm I think a bad day overall.
anchors is offline
Old 09-23-2010, 08:45 AM   #885
ges55
BLACK SATIN
ges55's Avatar
Put on the diamond plate bed & tail caps & the newer style tail light bezels
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline
Old 09-23-2010, 10:34 AM   #886
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by anchors View Post
..... promptly blew the freaking motor that is only about 200 miles old, blew chunks of the piston on #5 cylinder right out the side of the block. .......
Ohhhhh! Sorry. That's serious.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 09-23-2010, 10:51 AM   #887
scooterskoolkustoms
scooterskoolkustoms's Avatar
I had a good day,I pulled the gas tank,cleaned it, sealed it,got it ready to put it back in.I made a new transmission crossmember so my headers can tuck up nice and tight in the framerails and last I re-built my edelbrock carb.Now just have to put it all back together.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline
Old 09-24-2010, 10:45 PM   #888
67Slider
67Slider's Avatar
Got the 69 Camaro tank fabrication done and installed. I will bend the fuel lines and install them tomorrow. I like the way it came out.
[IMG][/IMG]
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 09-24-2010, 11:05 PM   #889
gonnuts
gonnuts's Avatar
Took the bracket for the steady bearing off the crossmember. The PO put a one piece shaft on but left the bracket, when I lowered it down it hit the drive shaft when I hit bumps. What a B*$*# of a job grinding the rivets off while lying under the truck.
gonnuts is offline
Old 09-24-2010, 11:10 PM   #890
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
67slider, that tank is AWESOME! More pictures please. How many gallons..is that the original filler area? Where ya get it at, how much? Will the behind the plate filler work?...
Drove to get gas for the first time in months! Hopefully gonna get it tuned morrow maybe?
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 09-25-2010, 02:01 AM   #891
pat 70/71
pat 70/71's Avatar
drove it to my shop, ran fantastic! love our trucks! cheers, Pat
pat 70/71 is offline
Old 09-25-2010, 02:07 AM   #892
magwakeenercew2jh
Originally Posted by gonnuts View Post
Took the bracket for the steady bearing off the crossmember. The PO put a one piece shaft on but left the bracket, when I lowered it down it hit the drive shaft when I hit bumps. ....
What do you think about a 2/piece drive shaft while using a 4/6 drop? All top notch stuff was used in the drop, including shock re-locator kit from ECE, if that makes any difference.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-25-2010, 08:38 AM   #893
67Slider
67Slider's Avatar
I took a bunch of pics with the goal of a thread all it's own. I will post up the whole thing when I finish up. I will have prices and vendors and all the misc stuff that I had to buy.
Hopefully be done today!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 09-25-2010, 11:00 AM   #894
gonnuts
gonnuts's Avatar
What do you think about a 2/piece drive shaft while using a 4/6 drop? All top notch stuff was used in the drop, including shock re-locator kit from ECE, if that makes any difference.[/QUOTE]
I would go with a 1 piece, especially if your going to be putting more HP under the hood. Looks better also, in my opinion.
gonnuts is offline
Old 09-25-2010, 02:26 PM   #895
Pont406
Pulled a motor out of the truck and pushed it out of the way outside. Almost done with a motor for a car. Need to finish a car first. After I'll decide what to do with a truck.
Pont406 is offline
Old 09-25-2010, 06:22 PM   #896
scooterskoolkustoms
It's 107 deg right now,the only thing I did was sift some sand getting it ready for my sandblaster.does drinking some beers sitting in the truck count as doing something?
Old 09-25-2010, 06:25 PM   #897
scooterskoolkustoms
I was thinking of putting in a one piece,do they have them or is it a custom made one?
Old 09-25-2010, 06:35 PM   #898
Hottrucks
Hottrucks's Avatar
Took my truck for a flogging!!!
yep local car club did 1/4 mile speed runs at the airport
Back to back 91 mph with over 150' of burn out......1 wheelie squilies sucks even with a 16.5 inch wire M/T
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 09-25-2010, 09:09 PM   #899
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I did a big fat smokey burn out in the garage tried to take pics but they sucked.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 09-25-2010, 09:14 PM   #900
dmwphoto
dmwphoto's Avatar
new dash and will put column in tomorrow
dmwphoto is offline
Closed Thread
