Old 09-23-2010, 12:09 AM   #1
flip66
flip66's Avatar
Front Control Arm U bolt
I am in the Garland TX area and in desperate need a Control Arm U Bolt ASAP. My girlfriends sons truck is setting in the school parking lot
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
Old 09-23-2010, 12:45 AM   #2
SCOTI
SCOTI's Avatar
Re: Front Control Arm U bolt
What year truck (disc or drums)?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-23-2010, 01:09 AM   #3
flip66
flip66's Avatar
69 converted to 72 disc brake
Old 09-23-2010, 01:26 AM   #4
SCOTI
SCOTI's Avatar
I have drum & disc u-bolts. You need one now?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-23-2010, 01:57 AM   #5
SCOTI
SCOTI's Avatar
Rangers game is over & I haven't seen a response so I pulled a disc brake u-bolt & it's sitting on my toolbox. I could meet you @ the school in the am I guess (none of the Garland HS's are that far from me)??
I'll check back in early morning.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-23-2010, 06:51 AM   #6
cdowns
cdowns's Avatar
autoparts sstore has common parts like this
Old 09-23-2010, 10:43 AM   #7
flip66
flip66's Avatar
I cant find the front one at a parts store I found the rear but not the front.
STOCI I sent you a PM
Old 09-23-2010, 11:41 AM   #8
flip66
flip66's Avatar
Thanks all I found them at NAPA
Old 09-23-2010, 11:52 AM   #9
SCOTI
SCOTI's Avatar
Around here, some do, some don't. I spoke w/him & suggested a local NAPA & he found what was needed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-23-2010, 12:25 PM   #10
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I know it's after the fact, but I got new one's from Napa as well, they are heavy duty for sure.
Part number is Napa 650-4065 comes in a two pack.
Hope it helps someone, sometime..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 09-23-2010, 12:45 PM   #11
paintpyro
paintpyro's Avatar
SCOTI, way to step up
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 09-23-2010, 01:18 PM   #12
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Thanks for the p/n Twisted! And rep points for SCOTI (if we had them that is)
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 09-23-2010, 01:54 PM   #13
c10seconds
c10seconds's Avatar
Good lookin out scoti!
c10seconds is offline   Reply With Quote
Old 09-23-2010, 02:53 PM   #14
SCOTI
SCOTI's Avatar
Well, he called me back & found out that the 'new' u-bolts are for disc equipped trucks & he has a drum x-member so they're too big. I'll get him one of the smaller dia ones so he can get going again tonight.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-23-2010, 04:14 PM   #15
72K20
Slow Old Timer
U da man! That, my friends, is what makes this board so utterly fantastic!
72K20 is offline   Reply With Quote
Old 09-23-2010, 08:36 PM   #16
ERASER5
ERASER5's Avatar
Either should have worked, the bigger ones just need to be smacked sideways with a hammer a little. BUT, when I did my disc swap, I compared the drum-smaller U-bolt to the disc-bigger U-bolt.
The older U-bolt was of a harder material. The "old" bolts cleaned up and looked like new, no pitting, perfect. The "new" were pitted badly and did not clean up at all. After I adjusted the bigger U-bolts, I did the same hammer tap to the old U-bolts. The new bolt bent just enough, the old bolts just bounced the hammer. I did a simple hardness test with a hammer and punch, again the old U-bolt showed up as harder. I used the old U-bolts. They were just better.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-23-2010, 09:01 PM   #17
flip66
flip66's Avatar
SCOTI came through big time great guy thanks again. I just could not see myself setting in a parking lot drilling through a frame with a cordless drill trying to get the 9/16 to fit.
