Old 09-22-2010, 04:33 AM   #1
96pappy
rough ride after drop?
I've got a 96 1500 ext cab short box that i did a 2"/3" drop on. spindles in front and shakle/ hanger in rear. After the drop the rear has a few ride problems.
1) when going over a bump the rear hits it hard, like there is no shock, but it does compress.
2) when there is any kind of load the ride is worse and the spring slams into bed rail. Is it common to cut the rail?
3) during accelaration there seems to be excessive vibration.
I did do the 2/4 drop at first but the ride was too crappy, so i raised the rear up 1". Are these common problems after this type of a drop?
any input is appreciated
thanks, mike
96pappy is offline   Reply With Quote
Old 09-22-2010, 08:35 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: rough ride after drop?
3) during acceleration there seems to be excessive vibration....
It sounds like the bed brace is your issue. If your shackle is hitting the bed brace you don't have full suspension travel in the rear. Yes, it is common to notch the brace.
You may need a degree shim to set your pinion angle. I found that some of my 88-98s did need it and some did not. If you have a small amount of driveline vibration on acceleration, you probably need shims.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-22-2010, 08:49 AM   #3
96pappy
the shackle is not hitting the bed brace, the clamp on the leaf spring is when under stress.
thanks for the reply
Old 09-22-2010, 10:17 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Can you post any pics of your suspension?
Keith
Convert to disc brakes.
Old 09-22-2010, 06:13 PM   #5
96pappy
i'll have time tomorrow, when the rain stops.
Old 09-23-2010, 06:22 PM   #6
96pappy
here are some pics. hope they help
Old 09-23-2010, 06:43 PM   #7
lolife99
lolife99's Avatar
Looks like your shocks are bottomed out.
I think you need a shorter drop shock.
Keith
Old 09-23-2010, 07:35 PM   #8
canadian trucker
A day should have 30 hours.
Agreed, when I did the static drop on my truck, I blew one the shoks apart, going over a bump.
Those seem to long
canadian trucker is offline   Reply With Quote
Old 09-23-2010, 07:40 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
If your shocks are still good you can use extenders as well. I like them because it gives you more range of travel.
Articles-
"Refining Sierra"
Old 09-24-2010, 06:00 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Is there a shock relocator kit for this era of truck? You need to adjust the direction the shocks adjust to offer a more verticle position vs. horizontal.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-24-2010, 06:31 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
The extender kit for 88-98 trucks move the lower mounting point down improving the degree of angle.
Articles-
"Refining Sierra"
Old 09-24-2010, 11:24 PM   #12
96pappy
First off, thanks for the tips.
I did notch the brace and installed 3 degree shims (from a kit for sale) to improve the vibration. Doing this seemed to improve the ride. Now I'm not banging the spring on brace and the shims improved the vibration. Overall the ride does not seem as harsh, but I think i will add the extenders.
thanks for the help
