Old 07-06-2010, 11:56 PM   #1
Critter
Future TOTM Winner
Critter's Avatar
Auto to manual pedal assembly???
I'm considering swapping out my stock th350 for a manual tranny. I have the mechanics of it figured out, but I am still a little unsure about the pedal. How big of a PITA is it to add a the clutch pedal or do I have to change the whole assembly etc. I plan to adapt a hydrolic master cylinder to it, but I would like the actual pedal to mount and look stock. Any body have any pics?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 07-07-2010, 03:05 AM   #2
raycow
Re: Auto to manual pedal assembly???
There was a thread on here not long ago with a very good pic from the shop manual. Anyway, your stock brake pedal shaft is hollow. The clutch pedal arm has a smaller shaft attached to it that goes through the hollow brake pedal shaft. The arm or lever for the pushrod clamps onto splines on the right end of the clutch pedal shaft and keeps it from sliding out.
Ray
raycow is offline   Reply With Quote
Old 07-07-2010, 03:13 AM   #3
John Pasinski
John Pasinski's Avatar
If you're interested, I've got a complete pedal assy, clutch, pressure plate, & SM465 out of a '73 that should fit. Although, the trans. bolt mount threads are oppisite between the '73 & up to '72. Everything's here in Orlando Fl.
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 07-07-2010, 02:36 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
That's what I was hoping for. I have taken pedals out of manuals to put in autos, but never the other way around. I wasn't sure if I was missing any details. I will keep looking for that thread
Thanks, but this is for a 6.0 LS swap with a nv4500 and a hydraulic clutch setup.
Old 07-07-2010, 02:47 PM   #5
bglad420
bglad420's Avatar
i have a complet pedal assembly out of a 72 still in the truck if your interested.
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50.
bglad420 is offline   Reply With Quote
Old 09-25-2010, 03:19 PM   #6
chevy71c10
chevy71c10's Avatar
I would be interested if they are still available? I was going with a 700R4 but have decided to go with a T-56.
Thanks,
Justin
Justin
71' C10 SWB
00' Dakota R/T
05' Z-71 Silverado
16' Z-71 Silverado
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904
chevy71c10 is offline   Reply With Quote
