Old 09-26-2010, 12:03 PM   #1
blackdawg
Blackdawg
newbie chevy 350 can you identify part.
haven"t torn down a chevy engine in 20 years.i have been marking everything keeping the bolts together and even been taking pictures.stuck on two things can you help me identify this part came out after i rolled the block over.i think it has to do with the oil pump.and there still seems to be a shiny piece sticking its head out by the end of the camshaft.i will attach a pic of the piece in question.other question how does the dam cam shaft come out.will it just pull out by the sprocket.i see three bolts at the back of it.square don"t have the right tool.after this clean it up and send to the machine shop.
blackdawg is offline   Reply With Quote
Old 09-26-2010, 12:05 PM   #2
blackdawg
Blackdawg
Re: newbie chevy 350 can you identify part.
Old 09-26-2010, 01:36 PM   #3
DPowers
One foot in front of the other
DPowers's Avatar
looks like an oil pump shaft
DPowers is offline   Reply With Quote
Old 09-26-2010, 01:46 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: newbie chevy 350 can you identify part.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 09-26-2010, 03:28 PM   #5
66GTO66C10
66GTO66C10's Avatar
Yes it is an oil pump drive shaft that goes between the pump and distributor.
1966 Chevy C10 frame off resto (In progress)
1966 GTO Numbers matching original
1989 Toyota Pickup (Tonka) resto
2002 HD FLSTC
2000 HD FLSTC
1996 Ninja ZX11
Believe nothing of what you hear, and 1/2 of what you see!
66GTO66C10 is offline   Reply With Quote
Old 09-26-2010, 06:38 PM   #6
blackdawg
Blackdawg
thanks guys
Old 09-26-2010, 06:44 PM   #7
TheDark1
Intentionally Left Blank
TheDark1's Avatar
That is indeed the oil pump drive shaft. The three "bolts" at the cam location are oil plugs. They don't need to come out to remove the cam. If the cam is stuck, make sure the oil pump drive shaft "sleeve" has come out on the oil pump. It is a small plastic or sometimes metal coupler that connect's the oil pump stub shaft to the oil pump drive shaft.
This one is metal and pinned to the shaft.
.Name:  22070oil%20pump%20shaft.jpg
Here the oil galley plugs are the pressed in type like freeze plugs. Most of them that I've seen are small pipe plugs with a square head.
I hope this helps, Jeff.
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 09-26-2010, 09:13 PM   #8
bama63
bama63's Avatar
and dont forget to remove the fuel pump push rod
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 09-27-2010, 12:26 AM   #9
Captainfab
60-66 Nut
That oil pump driveshaft uses the old style nylon coupling sleeve. I would replace it with an aftermarket shaft with the steel sleeve. They aren't expensive and are a recommended upgrade.
Old 09-28-2010, 12:53 PM   #10
blackdawg
Blackdawg
yes i surprised with a plastic sleeve.after some hard looking took out the fuel pump push rod and cam shaft came out easy.finally bare block.just soaking the piston tops in varsal to clean up the top and the ring groves.sending the block for hot tank ,honing,crankshaft,camshaft,pistons.will go to the machine shop .i will get them to check crank and cam to see if they need polishing.then get them to assemble pistons,crank,cam.i will do the rest not confident enough for the tolerances.
