63 rebuild
Whats up guys, I've been on this sight awhile checking out things, and decided to show you my build. This is a 1963 Chevy pickup i've had since 1985 when i was 16. It started out with a 460 ford motor in it, it had to go. I put a 350 in 3 years later and had it painted, drove it till 1992 and parked it. Been setting ever since. I decided to tear it down and give it a new life. http://67-72chevytrucks.com/vboard/a...1&d=1279506104
Re: 63 rebuild
UCA63
Re: 63 rebuild
Lookin' good boat
Love the mother-in-law seat LOL T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
Re: 63 rebuild
more pic
Re: 63 rebuild
Well down to the frame ,so this is where it starts
Re: 63 rebuild
A lot of work went into these pic, cleaning, scraping, grinding, sand blasting,then primer.now its clean enough to work with.
60-66 Nut
Re: 63 rebuild
That's cool that you've hung on to this truck this long....was it your first vehicle? Looks like it was pretty nice before you tore it apart. What's the basic plan this time around? Your truck is the ideal truck IMO.....A '63 Custom Cab, big back window, short fleetside
Re: 63 rebuild
I had a 71 nova before i got the truck , I,m going to go with the 2.5'' disc brake drop spindles, 4''/6 drop, to start with.
Re: 63 rebuild
trying to decide if i should buy a new fender or go with the replace patch http://67-72chevytrucks.com/vboard/a...1&d=1282013798
60-66 Nut
Re: 63 rebuild
I would definitely patch your existing fender. In fact you should be able to repair that with just a piece of 18ga cold rolled sheet. All you need to do is put that little bit of a curve and the lower body line in it. That's what I would do. You might need that inner support also. The new replacement fenders leave some to be desired and require some work to get them in shape.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-17-2010 at 12:58 AM. |
Re: 63 rebuild
painting the frame
Re: 63 rebuild
early classic drop spindles with disc brakes. front end rebuild kit by moog, and 1 '' drop front coil springs and 5 '' drop rear springs. adjustable panhard bar, kyb shocks
Re: 63 rebuild
need to find a power steering box
UCA63
Re: 63 rebuild
That's looking great Boat
Is that the original trans x member,just moved rearward?(sans lower supports) If so,what kind of E brake set up did you have? I'm at about the same stage with mine(also a '63)and need to make a decision soon on what I'm going to use.I'll be running a TH 350. Thanks,T
#15 |
Re: 63 rebuild
no its not the original trans member .when i bought the truck it had a 460 ford engine in it ,when i dropped the 350 in i used the same cross member just moved it around a little works fine, don,t know what it came out of . as far as e-brakes i never had any cables ran anywhere so i need to figure that one out.
#16 |
Re: 63 rebuild
more pic
#17 |
Re: 63 rebuild
rear end
#18 |
Resistance is Futile
Re: 63 rebuild
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#19 |
Re: 63 rebuild
been doing some cleaning while waiting on parts to come in.
#20 |
Re: 63 rebuild
and did put in new u-joints
#21 |
1 thing at a time is progress.
Re: 63 rebuild
NIce work!! Subscribed!!
Alan
Philippians 2:14-16 |
#22 |
Re: 63 rebuild
Thats awesome, Boat! Subscribed for sure!
#23 |
Re: 63 rebuild
sandblasted and painted some parts
#24 |
Re: 63 rebuild
the new blasting box
#25 |
Re: 63 rebuild
got my new power steering box ,just waiting on the conversion kit from classic parts
