I'd check operation of the choke first. Then check the fuel filter. Not sure what you mean by "cleaned it up" but you're probably needing to disassemble and clean. The throttle shafts wear on these Qjets providing air leaks that can result in your symptoms. Ask your performance / speed shop where there is a carb man who will rebush the shafts for you.
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock http://www.oplnk.net/~spirit/K5front.jpg |
| Bookmarks |
