09-27-2010, 10:37 PM | #1 |
aftermarket tach ??
ok i have a sunpro tach i got out of a different truck i had and set it on the shelf for a while and now wann thow it in my stock crewcab but kinda unsure where to hook the signal wire to
my buddy says it hooks to the - wire on the hei plug the the rest is power ground and dimmer my question is i looked at and hei dist. that i had sittin in my garage and it has a tach out put and looks like a plug goes in there and the one on the truck looks the same but im wonrdering if need to find a plug is it already in there can i attach the wire to somethign else im new to the gm stuff and i know toyta 22rs really well so any help would be appreciated and if any one has a pic or 2 the help thanx in advance |
09-29-2010, 01:33 AM | #3 |
Re: aftermarket tach ??
thanx i kinda looked earlier the dist doesnt seem to have the plug for the tach plugged in can i get one from a local auto parts store or do i go junk yard hunting for it
09-29-2010, 01:46 AM | #4 |
I know the pieces fit
If you look under the cap you'll see a male blade connector. It's marked on the top of the cap as TACH. Solder or crimp a female blade connector on the green wire and push it on that male blade connector and you're good to go.
09-29-2010, 01:49 AM | #5 |
cool ill probably end up doin that it did cross my mind but the blade looked alittle bigger than normal but ill see what i can come up with
