Old 09-19-2010, 08:17 PM   #1
61apachespeed
electric fan ???
i have a 61 apache i am trying to put a electric fan in front of the radiator. both it hits the cross bars in front. what do the cross bars do?? and can i cut them out??
61apachespeed is offline   Reply With Quote
Old 09-19-2010, 08:27 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: electric fan ???
They brace the rad support, could you remove them, they remove them when installing a condenser for A/C.
Old 09-19-2010, 09:08 PM   #3
6863m
I just put a fan in my 62 and put it in front and it clears the pulley by about an inch. Is there a difference which side.
6863m is offline   Reply With Quote
Old 09-19-2010, 09:23 PM   #4
nachodog2
Hell yeah!!!
nachodog2's Avatar
If you have the room and the interference isn't very much you can space the radiator a bit to move it towards the motor.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 09-20-2010, 12:33 AM   #5
Captainfab
60-66 Nut
Typically electric fans work more efficiently as pullers.....on the engine side. Of course your fan has to be either reversable or already working as a puller. If you need to install your fan in front of the radiator, I would remove the X brace on the radiator support. None of mine have that X brace there and I haven't had any problems with the radiator support.
Old 09-27-2010, 11:05 AM   #6
wlevick
Here is mine.
wlevick is offline   Reply With Quote
Old 09-29-2010, 11:59 AM   #7
srsummers
What kind of HP increase do you gain when switching to an electric fan?
srsummers is offline   Reply With Quote
Old 09-29-2010, 12:09 PM   #8
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
5-10 maybe?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-29-2010, 01:34 PM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
More than the horsepower gain, I prefer the constant hum of an electric fan compared to the screaming you can get from a variety of stock and aftermarket fans at higher rpms.
Old 09-29-2010, 11:45 PM   #10
Captainfab
60-66 Nut
I feel that your engine gets up to operating temperature quicker with an electric cooling fan(s)
Old 09-30-2010, 01:17 AM   #11
Heater63
Heater63's Avatar
Yes, you're removing a load by eleminating the mechanical fan; But, you have to make a lot of electricity to run those electric fans; it takes more power from the engine to turn the alternator at a higher loading to produce that electricity. In fact, you might need to get a bigger alternator to add electric fans.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 10-01-2010, 12:17 AM   #12
61apachespeed
i am running a 95 amp and a 2400 cfm spal eleic fan. i run about 180 to 190 temp. i have a 180 robert shaw themo.
