#151 |
Grandpa in the rustmobile...
Re: My 65 Pickemup project
lol different...why not just put a column stock shifter back on lol...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#152 |
Kvn1011
#153 |
![]() Join Date: Feb 2003
LOL ya it's the e brake. You wouldn't believe how good it works.
#154 |
Kvn1011
that is a slick idea!!
awesome truck too! ![]() |
#155 |
1961 crewcab
like that idea!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#156 |
that idea is awesome! now, where did i put that ebrake lever....
Build Thread - Papa's truck build up |
#157 |
Registered Loser
Wow, that's creative! I wanted to do something similar with the e-brake from my truck. It had a tranny mounted e-brake with a lever through the floor.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#158 |
60-66 Nut
That's really a cool idea. So which way is park, all the way down or up?
#159 |
All the way down for park, ratchets up into gear. Drive is only a couple inches from it's down position. I didn't even have to drill any holes, used the original holes for the ebrake cable. just a simple bracket for the cable housing.
#160 |
Forgive me if I steal that idea... Very creative.
#161 |
Super cool!
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#162 |
sweet picture man. Its gonna be my background.
#163 |
Insert Title Here
Coming along awesome.....looks great
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
#164 |
chevy only
![]() Join Date: Sep 2006
Delmo is this truck drivable already?
CHEVY ONLY... Nothin Else ! |
#165 |
Pretty close, just need to wire it and break in the engine. The accuair needs to run its set up but I don't think that takes long.
Looks like an AZ trip might be in order. |
#166 |
chevy only
Yes It do!!! Still need the plug for the engine harness? I am busting some butt to get sub out to goodguys i told nate he is welcome to drive it out
CHEVY ONLY... Nothin Else ! Last edited by Dinos63; 09-22-2010 at 12:45 AM. |
#167 |
Very cool, we might have to BBQ somewhere that weekend. I'll PM ya with my address, could use that plug. Thanks man.
#168 |
Correct, I have pinion angle where I would like ride height to be. Until I drive it and determine where it steers and rides best I won't nail down a premanent ride height and set pinion angle to suit. I would like ride height to have rockers about 2.5 inches from the ground but we will see I guess. The rear shaft ended up being pretty short the way the driveshaft shop put the slip joint together so I'm hoping it doesn't give me any issues. I'll get some angles and measurements from my set up soon.
#169 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Damn nice build glad sam pointed me in this direction....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#170 |
Delmo,
Any updated pics of the truck since you finished it? Do you have any pics of the driveshaft? Tony from Norcal |
#171 |
I'll get some pics of the shaft tomorrow. Going to start on the bed wood this week.
Man I love that Accuair. |
#172 |
Here is the pic of the driveshaft you wanted, hope this helps. Also an update.
Cut 2 5/8 out of the wheel wells and built a structure to put some wood back in. Broke in the engine and bled the brakes. Wired up some cheapy gauges and got the ligts workin. This thing is almost ready to drive. ![]() ![]() ![]() ![]() ![]() |
#173 |
Some more crappy pics.
#174 |
Sick!
#175 |
![]() Join Date: Jul 2010
Looks Great!!!! BTW how fast does that compressor fill your tanks? I've never seen one of those before, where did you find it?
65 GMC lwb |
