Closed Thread
Old 09-27-2010, 11:18 PM   #1876
sams60gmc
sams60gmc's Avatar
Re: What did you do to your truck today?
Today I started building 2 solid aluminum ball bearing watts link center sections. One will be mine and one will be Lukes.. (frenchblue72)
Then I got some more work done on the drip rail shave.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 09-28-2010, 10:38 AM   #1877
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
I finaly got 700r4 up and running yesterday. And today will finish power door lock on passenger side. And. I'm hoping to see if I have enought metal to start working on the bed
Sick5 is offline
Old 09-29-2010, 02:07 PM   #1878
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Finish both doors with power Door locks
Sick5 is offline
Old 09-29-2010, 02:50 PM   #1879
knuckledragger
knuckledragger's Avatar
Installed the 78 front suspension.Waiting on captfab to send me the p/s adapter.
knuckledragger is offline
Old 09-29-2010, 04:42 PM   #1880
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Monday evening I put my valve covers and air cleaner on.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Old 09-29-2010, 08:26 PM   #1881
Bugeyev8
Bugeyev8's Avatar
Fabbed up the rear bumper brackets and a hidden reciever hitch today, I did not have room for a class 3 hitch between the bumper and bed. I used the smaller one should be fine as I do not plan to tow anything over the 4k rating the reciever has, I could have bought the brackets from LMC for 98$ plus their bend you over shipping but...I wanted the bumper tucked in and higher than the factory mounts them
Bugeyev8 is offline
Old 09-29-2010, 09:28 PM   #1882
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Excellent Idea!
aerotruk63 is offline
Old 09-29-2010, 09:31 PM   #1883
aerotruk63
aerotruk63's Avatar
Started fabricating the exhaust system. 2 1/4" OD out of the manifold to a Stainless Dynomax muffler the sales rep left behind.
Old 09-29-2010, 10:47 PM   #1884
fryer1979
Redneck Hillbilly
fryer1979's Avatar
YES!!! Love those air cleaners! The valve covers look pretty sic too.
fryer1979 is offline
Old 09-29-2010, 10:52 PM   #1885
60apache
60apache's Avatar
installed the fast ez efi kit
60apache is offline
Old 09-30-2010, 10:37 PM   #1886
knuckledragger
Installed my p/s adapter and prepped it for welding.
Old 10-01-2010, 01:33 AM   #1887
Legend56BC
Legend56BC's Avatar
Thumbs up Re: What did you do to your truck today?
I cut out the trans cross member in my daughter's 60 GMC to put a Turbo 350 behing the big six..
Legend56BC is offline
Old 10-01-2010, 02:07 PM   #1888
Vernski
Hey Legend nice build on #72 you put allot of work in to it thanx for sharing the pic's if you have pic's of your daughters 60 GMC when it's done I would like to see those also.....Vernski
Vernski is offline
Old 10-02-2010, 11:29 PM   #1889
narx66gmc
painted the remaining two center caps and got one coat on the wheels before it was too windy. got the bumper scuffed and primed for paint on tuesday. Located the two tires i'll run on the front, i'll get those mounted tuesday. taped the roof off for painting, maybe sand and prep tomorrow.
Build Thread - Papa's truck build up
narx66gmc is offline
Old 10-03-2010, 02:49 AM   #1890
d00de
d00de's Avatar
nothing major...chrome trim on wheels. but boy did it make a difference in appearance!
d00de is offline
Old 10-04-2010, 08:40 PM   #1891
Cops053
Cops053's Avatar
Pulled out all the bed wood, was Pine that was faded out. Was going to replace it with Oak that I have that is rough sawn, after I cut to size and plane, stain and coat with lots of varnish, but also have a nice supply of Eastern Red Cedar that has been drying for a year.......so trying to decide if the cedar would look good in it. Tomorrows plan is to clean all the exposed frame and rear end, prime and paint.
Cops053 is offline
Old 10-04-2010, 09:09 PM   #1892
Turkey
Turkey's Avatar
I vote cedar.
Turkey is offline
Old 10-06-2010, 03:29 PM   #1893
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
busy today, put in a new choke cable, think I might have run all summer with the choke partially closed, because it was all jammed up.
fixed a broken lever on the heater, and put in a working heater switch.
(this was easier said than done!)
pulled the kickpanel vents, and vaccumed out the air box, a critter had taken up residence there years ago I guess, full of pine cones and pine needles.
replaced the pionts, cap , rotor, and condenser. the cap and rotor were so corroded I am not sure how it even ran.
this was all on my 65 dd
jonzcustomshop is offline
Old 10-06-2010, 04:58 PM   #1894
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
nothing major, new peep mirrors.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 10-06-2010, 05:28 PM   #1895
65Gregg
65Gregg's Avatar
Got a call from the powdercoater telling me my rallye wheels are ready. I am glad that I'm getting closer to taking off the current ones. Now I can start working on new tire sizes. The manager at the local Tire Max says to bring my truck in and he will mount tires and put them on the truck until I find the size that gives me the stance I want. That is sweet. come to find out he has a 63 shortbed and a bagged and body dropped 46.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 10-06-2010, 08:23 PM   #1896
66 jewels
66 jewels's Avatar
i got my horn working after 3 years and i think my altenator working as well , I was told the guy that helped me redo my truck wired it wrong, the guy owns 4-5-6 chevy truck
66 jewels is offline
Old 10-06-2010, 08:35 PM   #1897
CVA59
Finally got the frame and all the suspension pieces to the sandblaster. Will pick everything up tomorrow.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline
Old 10-06-2010, 08:57 PM   #1898
bigdaddy64
bigdaddy64's Avatar
Got my firewall filled and ready for body filler, next is the drip rail. Previous body work left much to be desired, a portion of rail on pass side back corner is all bondo.
66 c20 with 1/2 ton 73-87 front and rear suspension
2-1/2" drop spindles, air-bags, c-notch rear frame
463 Pontiac, SRP Pistons, Eagle Crank and Rods
Mega-Squirt Fuel Injection
bigdaddy64 is offline
Old 10-07-2010, 12:26 AM   #1899
66 jewels
66 jewels's Avatar
just found where the same 4-5-6 chevy truck put my wiper linkage together wrong, i might get wipers now after 3 years of not having them
Old 10-07-2010, 08:17 AM   #1900
SRVBLUES64
I took the day off to work on my truck. I ended up building a table with wheels so I can place the cab a little higher. Without a lift it was tough when your by yourself. But I did it and now Im home again with 2 torn discs I should have known better.
SRVBLUES64 is offline
Closed Thread
