Old 10-01-2010, 04:40 AM   #1
Number21
Number21's Avatar
Replacing door lock cylinders?
I just aquired a nice old '73 K20, unfortunately it did not come with any keys for the doors. I found a matching set of door lock and ignition cylinders for about $25, it would be nice to have only one key for all. How difficult would these be to install in the doors? I'm not sure if this is a project I want to do myself, but I need to get it done ASAP because my truck is unlocked until I can fix it...
Number21 is offline   Reply With Quote
Old 10-01-2010, 06:05 AM   #2
LONGHAIR
Re: Replacing door lock cylinders?
It's a fairly easy job. Most people find that removing the window crank is the hardest part. You have to remove the interior door panel (upholstery). From that point it is really just a matter of popping the clip off of the lock rod and the larger clip that holds the cylinder to the door skin.
It is essentially a reverse of everything to put it back together.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-01-2010, 02:32 PM   #3
donut
donut's Avatar
like Longhair said, it's a fairly straightforward process.
Have you tried the obvious first? My '73 only has 1 key, but it took some time and penetrating oil to get the door cylinders freed up.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 10-01-2010, 03:59 PM   #4
nbpro
Slip it behind the window crank to quickly remove the spring clip. One of the "must have" tools if you intend to service automobile locks
nbpro is offline   Reply With Quote
Old 10-01-2010, 04:40 PM   #5
Adams74Chevy
Adams74Chevy's Avatar
Attachment 638906
Or...you can always use a shop rag behind the crank and turn the crank and viola! off comes the clip, not saying the tool isn't worth it's weight in gold...heck I own one but sometimes it's not with you when you need it.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 10-01-2010, 05:56 PM   #6
nbpro
this ture
