MC has been purchased and installed
What do you mean by factory set up, I've never seen a stock assembly as my truck was hacked up before I got it
Originally Posted by mr48chev
If I had a swing pedal I would run the brake light switch and lock up switch on my brake pedal just like the factory setups. The other option would be a Ford style inline switch ( I have one on my 48) that operates on pressure from the brake line. Easy to find example but I am in no way suggesting that you buy this one as they are available in any parts house http://cgi.ebay.com/ebaymotors/Brake...Q5fAccessories
I put that one in because my floorboards were hacked up were the stock one went but I will use a stock AD Pickup brake light switch when I put the truck back together.
If you haven't already bought the booster and master cylinder I would seriously think about running a hydro boost like DWCSR suggested. With that engine setup it would work a lot smoother and once you drive a vehicle with hydroboost you hate to go back to the vacuum booster. The only thing you would have to change with the power steering is the pump if you even had to change it and add a pressure and return line to the hydroboost.
