I need the following parts to get my truck on the road:
drivers side headlight bezel (single headlight) radiator shroud ( I have a 350 in the truck if it matters) transfer case shifter boot (it has an NP203 in it) Anyone parting out a 81-87? I need some parts. Thanks!
76 Gmc Vandura Custom, RIP 82 K30 4x4 6" Lift, Built 350, many mods 84 cutlass 350 chevy out of my vandura ![]() |
#2 | |
Re: I need these parts for my 82 K10
On dvr side headlight bezel, you mean the one piece outer trim that covers the headlight and signal light? On the shroud, it is a 2 piece unit. You need upper or lower or both. fastr68 has a transfer case shifter boot that might work for you. Email me directly so I will have your email to send you pics when I find the parts to make sure they will be the correct ones. Tommy Davis
junkyardpartseeker@sbcglobal.net Last edited by junkyardpartseeker; 06-08-2003 at 07:18 AM. |
I have an 83 K20 rolling chassis with drive train and some sheet metal for sale.
This has a 3504BBl with 4spd and NP208. I have some sheet metal, hood, fenders, radiator support. I also have that shroud. I might have headlight doors but they are only single light doors. I am 30 minutes north of Columbus. Let me know what else you might need. ric |
#4 | |
ric
upper and lower fan shroud single dvr side headlight bezel with lines underneath due to their signal is in the bumper. If you can help them out, let me know and I will check them off the list. If you email me directly, I can give you their email address. Tommy Davis
junkyardpartseeker@sbcglobal.net |
I also need a driver's side door panel, preferably in burgandy.
Still need a headlight bezel... may end up getting it from LMC if I can't locate a good used one. Thanks guys for the help so far!
