![]() Join Date: Jun 2007
what years of 12 bolt will fit
I would like to get a 12 bolt housing for my 4X4 72 Jimmy that I can powdercoat and rebuild over the winter. What years will work?
Thanks Mark
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
![]() Join Date: May 2007
Re: what years of 12 bolt will fit
According to the interchange book...72 chevy/gmc truck and 72 blazer/jimmy. One year only. I'm not sure what the difference is between other years. 1970 and up use the same length axle shaft, so it must be some thing minor like a brake issue or something. I think the book considers something to be interchangeable, as something that doesn't require a single bolt to be changed.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
I put a 2WD 12 bolt in my truck and it's a little wider than stock, better than the narrow original...
I think that you can make about anything work from solide axle chevy's. 2WD's will require that you weld on spring perches but that's easy... www.diy4x.com
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Thanks both of you. In my situation welding on spring perches would not be an option as I am trying to have it powdercoated and rebuilt ready for installation to decrease down time. I had my Jimmy tied up for 6 months plus with the 5.3 swap and I would like to be able to swap axles in a weekend.
So anybody have a 72 4X4 12 bolt housing hanging around?
I believe the difference is the routing of the brake hard lines and the location of the tee. To use the "wrong" year housing you have to relocate the tee or the hose.
Ray |
I basically gave my old axle away because I didn't want to store it, sorry... I picked up a 3.73 posi 12-bolt at the Junkyard for $35....
I have 4-5 local junk yards 5 miles from my house. They have nothing for these old trucks
![]() Join Date: Jul 2005
I bought a 12 bolt posi from Kingsolver. It fit with no issue's other than as one mentioned above the brake t and the lines were a bit different. MY HEAP IS A 68 the unit from Kingsolver I believe was a 70 or 71. Not sure now. it was as one mentioned above a little bit wideran inch or two.
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
