Old 10-02-2010, 05:23 PM   #1
Thealien
Thealien's Avatar
what years of 12 bolt will fit
I would like to get a 12 bolt housing for my 4X4 72 Jimmy that I can powdercoat and rebuild over the winter. What years will work?
Mark
Old 10-02-2010, 06:57 PM   #2
turp mcspray
turp mcspray's Avatar
Re: what years of 12 bolt will fit
According to the interchange book...72 chevy/gmc truck and 72 blazer/jimmy. One year only. I'm not sure what the difference is between other years. 1970 and up use the same length axle shaft, so it must be some thing minor like a brake issue or something. I think the book considers something to be interchangeable, as something that doesn't require a single bolt to be changed.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-02-2010, 08:04 PM   #3
msgross
msgross's Avatar
I put a 2WD 12 bolt in my truck and it's a little wider than stock, better than the narrow original...
I think that you can make about anything work from solide axle chevy's. 2WD's will require that you weld on spring perches but that's easy... www.diy4x.com
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-02-2010, 09:45 PM   #4
Thealien
Thealien's Avatar
Thanks both of you. In my situation welding on spring perches would not be an option as I am trying to have it powdercoated and rebuilt ready for installation to decrease down time. I had my Jimmy tied up for 6 months plus with the 5.3 swap and I would like to be able to swap axles in a weekend.
So anybody have a 72 4X4 12 bolt housing hanging around?
Old 10-03-2010, 01:59 AM   #5
raycow
I believe the difference is the routing of the brake hard lines and the location of the tee. To use the "wrong" year housing you have to relocate the tee or the hose.
Ray
raycow is offline   Reply With Quote
Old 10-03-2010, 08:42 AM   #6
msgross
msgross's Avatar
I basically gave my old axle away because I didn't want to store it, sorry... I picked up a 3.73 posi 12-bolt at the Junkyard for $35....
The Garage:
Old 10-03-2010, 09:56 AM   #7
Thealien
Thealien's Avatar
I have 4-5 local junk yards 5 miles from my house. They have nothing for these old trucks
Old 10-03-2010, 04:01 PM   #8
larry may
I bought a 12 bolt posi from Kingsolver. It fit with no issue's other than as one mentioned above the brake t and the lines were a bit different. MY HEAP IS A 68 the unit from Kingsolver I believe was a 70 or 71. Not sure now. it was as one mentioned above a little bit wideran inch or two.
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
