Old 10-03-2010, 01:33 AM   #1
SuperNova22
76 stepside fuel tank filler
Ive been going crazy trying to find a replacement fuel tank filler hose that goes from filler neck to tank. Called every parts store, searched online and no luck. Is this one hose actually going to be a dealer only item? Not sure if the dealer can even get it. Any insight on this would be great!!
SuperNova22 is offline   Reply With Quote
Old 10-03-2010, 06:37 AM   #2
S10Fan
Old Heap Driver
Re: 76 stepside fuel tank filler
From what I remember (on here), guys have been using fuel resistant hose from various sources because GM no longer offers them.
Hopefully someone will jump in and post an answer.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 10-03-2010, 02:42 PM   #3
HumbleChevyBuddy
HumbleChevyBuddy's Avatar
I found this on Oreilly Auto Parts site:
HumbleChevyBuddy is offline   Reply With Quote
Old 10-03-2010, 08:07 PM   #4
SuperNova22
Well ive checked there too. Those are not exactly the ones im looking for. Those are straight, but can bend. The original hose has 2 sharp bends in it in opposite directions to get to the filler neck. Not sure if those would make it. Looks like you have a stepside also. Would that hose work on yours? This might be an option but im trying to find an OEM hose that will fit perfect before i try and rig something.
Old 10-03-2010, 08:47 PM   #5
HumbleChevyBuddy
I've been meaning to change mine out, so I'll order one and see how it goes. I'll keep you posted.
Old 10-03-2010, 10:16 PM   #6
BigRed76
BigRed76's Avatar
I bought some fuel resistant hose similar to what HumbleChevyBuddy posted, it was ribbed on the out side and smooth on the inside. It was like $25 for 4 feet of it. I used about 2 feet of it on my stepside and it worked like a charm.
I never found a company that made the OEM hose for the stepsides so i used to stuff from the parts store.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 10-03-2010, 10:35 PM   #7
HumbleChevyBuddy
What size did you end up using for this? 2", 2 1/4", or 2 1/2"?
Fernando
Project "FATBOY" build thread
The key to happiness is having dreams. The key to success is making your dreams come true.
Old 10-03-2010, 11:22 PM   #8
BigRed76
BigRed76's Avatar
The stuff I used was 1 1/2". The PO had replaced the OEM hose w/a piece of radiator hose, which didn't work very well at all. The new hose was a perfect fit on the filler neck and on the gas tank.
Zach
Old 10-04-2010, 08:49 PM   #9
SuperNova22
Thanks, i appreciate all the help. I called up Kragen Auto Parts and they had 1 1/2'' gates fuel hose in stock, which is the same diameter as the original hose. $12.00 per ft. So im gonna be heading down there right now to pick some up and see how it goes.
Old 10-04-2010, 09:43 PM   #10
SuperNova22
So im back from Kragens. And wouldnt you know it, the hose i called about was wrong. Could not make the sharp 90* bends. So started talking to the guy, he let me go in back and look around. Found 3' of the ribbed Gates fuel hose 1 1/2'' and will perfectly make the bends. Downside : its $22.00 per foot. Guy hooked it up a little, plus i have a commercial account there. So i got away pretty cheap considering. Havent installed it yet but i know it will work. Again, Gates Fuel Fill Hose PN: 23924
Old 10-05-2010, 01:00 AM   #11
BigRed76
BigRed76's Avatar
Glad you found what you need...But wow what a price difference. When I bought mine a paid around $22.00 for 4 feet of it
Zach
Old 10-06-2010, 11:34 PM   #12
SuperNova22
Just a quick update. Eventhough the hose was expensive, i got it in. And it fits perfect. Clears the edge of the bed and looks really good. Not like anyone will be seeing it, but i will know. It might have cost alot but for not being able to find the OEM hose, This works great. Thanks for all the help!
Old 10-07-2010, 05:21 AM   #13
S10Fan
Old Heap Driver
That's good to know, thanks for posting a followup.
Bryan
Old 10-07-2010, 12:38 PM   #14
HumbleChevyBuddy
Sweet! I'll be changing mine out very soon (just ran into some other projects), but thanks for the update!
Fernando
