06-05-2003, 08:56 PM | #26 |
Calibration Engineer
hey, thanks a lot jeff!! btw.. i'm using a holley elec pump but there's no regulator.. red pump.. doesn't need one.. fact. set at 7 psi.. the filter is a summit canister style. pump and filter are both 3/8 npt fittings. Also, why do i need a 90 deg. swivel for the vent? can't you just bend the line to where you need it? i don't see the point of the 90 deg. fittings when you can just bend the line where it needs to go.. am i missing something? once again though thanks for the list! almost got it visualized how and where everything goes together now..
CANADIAN CONNECTION |
06-05-2003, 11:14 PM | #27 |
yeller
I just suggsted that for looks and "wow" factor, you can do what you said or do what Greg did, get a 90 deg non-swivel...all three will work. Glad I could help.
...Jeff |
06-05-2003, 11:27 PM | #28 |
Project92 SWB stepside
I like the tank mod there!! I had problem with my tank on my 83 when i took it to get a alignment. I came back to pick it up and noticed a pan under the truck catching gas as it dripped. They tore a hole in it pulling it onto the rack. I will be adding a fuel cell as well.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
06-05-2003, 11:49 PM | #29 |
just wondering what the point is to getting a swivel as opposed to a non-swivel..?? still new to this AN stuff.. also, what's a bulkhead??
06-06-2003, 12:48 AM | #30 |
For you guys going from carb to fuel injection and don't want to modify any thing at the tank,I saw a pretty neat deal in one of my catalogs the other day,think it was Summit or Jegs.It is a tube with an inlet that you splice into your fuel filler hose and dump the return line back into the tank without having to braze an inlet to the tank itself.Pretty ingenious.
Good Luck Tom
76 Silverado 74 Vette |
06-08-2003, 12:36 AM | #31 |
BAD BOW-Silverado XST
Great job. I like it.
06-09-2003, 01:30 PM | #32 | |
been here longer than Liz
As for using the braided line, the best combination of tips I found was to measure then wrap the area to be cut tightly with electrical tape. Make the cut using tin snips (thanks Mike!!!), which will allow you to 'clean up' the cut. Leave the tape on and use STP oil treatment for lube (thanks again Mike!). Work the hose into the fitting with a lot of pressure and a twisting motion. Once it's in, trim the exposed tape with a razor. Screw the other side of the fitting in, if done properly the tape should remain hidden. Good luck!
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
06-09-2003, 03:10 PM | #33 |
Trucker.
Looks sweet, since I'm keeping the 83 this is high on the list of priorities.
06-09-2003, 04:38 PM | #34 | |
BeWarE tHe eViL CrAnkTOe!
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
06-09-2003, 04:51 PM | #35 | |
06-09-2003, 07:05 PM | #36 |
I'm back with 2nd truck!
GREAT!! Glad to see you keep it Izzy
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
06-10-2003, 01:05 PM | #37 | |
Trucker.
06-11-2003, 10:22 AM | #38 | |
