Old 06-11-2003, 08:48 AM   #1
BigBlack68
Negative Camber
BigBlack68's Avatar
Question Gas gauge hook up
This might sound stupid but...how do i hook up my gas gauge? i have no wire that says "FUEL" and no wire running to the gas tank from the gauges,can i just hook up a wire from where it says "FUEL" on the fuse block back to the tank then ground it? i really need help,dont like not having a gauge,thanks again
BigBlack68 is offline   Reply With Quote
Old 06-11-2003, 11:54 AM   #2
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
You should have a brown wire running from the fuse block terminal to the sending unit on the tank. The tank should be grounded due to the way it is mounted.
If you ground the brown wire, your guage should move to empty. If it is open, the guage should go past full.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 06-11-2003, 02:37 PM   #3
BigBlack68
Negative Camber
BigBlack68's Avatar
Ok i'll have to try that,thanks alot for the help
