Old 10-02-2010, 01:03 PM   #1
dbmx66
for all you guys wishing you had a different lug pattern
took me an hour and a half to do in shop on one of the bridgeport mills.
indicated the the center of the the bearing race in the center of rotor, popped the old studs out. drilled and spotfaced new holes. the new bolt circle is within .0005 of being perfect with the hub. so my wheel will be rolling nice and smooth down the road.
and yes i know they arent centered in between the previous holes, because theres a gusset there, you can see in the picture.
i changes them from 5x5 to 5x4.75
dbmx66 is offline   Reply With Quote
Old 10-02-2010, 01:31 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: for all you guys wishing you had a different lug pattern
Well done. Looks great.
That is exactly how we changed the bolt pattern on our '63 Tempest (went from the production 4.5" to a more typical 4.75"), except that we "spotted" through an existing A body drum to mark the locations.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-02-2010, 01:45 PM   #3
dbmx66
yea, whatever gets the job done. hopefully these rotor will last for a while hahaha
Old 10-02-2010, 02:21 PM   #4
SBTork
Garage wrench
SBTork's Avatar
awesome work man!
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 10-02-2010, 02:24 PM   #5
jitteryguy
GoatLube Experss
jitteryguy's Avatar
looks good, are ya do'n the rear also ? I put a 9" ford in my MonteCarlo and had the axles and rotors redrill'd to the chevy pattern , they had to offset mine just you did . 2 yrs now, still hold'n up good .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 10-02-2010, 03:12 PM   #6
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Sweet man, nice work!!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 10-02-2010, 03:15 PM   #7
Stitch
Location: Where I come from, it's cornbread and chicken...
very nice
Stitch is offline   Reply With Quote
Old 10-02-2010, 03:25 PM   #8
dbmx66
thanks guys, i dont need to do that for my rear, mines narrowed with custom moser axles. the only thing i might to is drill them to 5/8 for 5/8 studs for racing.
Old 10-02-2010, 06:17 PM   #9
knightowl73
TUKE-NoBullChit Customs owner
knightowl73's Avatar
ya do know 73 chevy van, only 73, had 5x4.75 pattern and is direct bolt-on for our trucks right? right?
OWNER @ NBC Customs...No Bull Chit....'92 GMC C2500 ECSB 350/TH400, '57 FORD SKYLINER (My dad's for now, but its really mine-you'll NEVER see a cooler car at 7 years old lol), '42 ford rat rod shop truck (new project), 91 CHRYSLER VOYER MINIVAN (shop van for now)
http://www.facebook.com/#!/nbc.customs
knightowl73 is offline   Reply With Quote
Old 10-02-2010, 08:19 PM   #10
dbmx66
well i got just fresh rotors, and the chances of finding a 73 van with decent rotors seems pretty rare to me.
Old 10-02-2010, 10:35 PM   #11
3r!c84
Badass
3r!c84's Avatar
what wheels you planing on putting on your truck
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-03-2010, 12:01 AM   #12
dbmx66
i have 15x4 front and 15x15 rear draglites.
i plan on getting weld magnum 2.0s wen i switch to strut front suspension.
Old 10-03-2010, 12:12 AM   #13
Stitch
I think what he was getting at is that you just bought new rotors for your truck. You could have bought new rotors for a 73 chevy van instead and not had to drill your new rotors.
Old 10-03-2010, 01:04 AM   #14
knightowl73
yeah i was sayin that exactly
Old 10-03-2010, 03:28 AM   #15
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Well, that's one way to fit S10, car and Vette wheels.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-03-2010, 11:24 AM   #16
dbmx66
well i guess wen these wear out, ill get some van ones.
Old 10-03-2010, 12:35 PM   #17
79gmcclassic
79gmcclassic's Avatar
nice tempest
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 10-03-2010, 03:46 PM   #18
LiveWire64
LiveWire64's Avatar
Not true.
The 71-74 G10 vans all had 5x4.75. The 71 & later G20 vans had 5x5.
Late 74,early 75 is when the G10 vans started using the 5x5 pattern.
I have done extensive research on this & the bearings are different between the two patterns. How did you put them on your truck?
Thanks for any info. Brad
55 Chevy small window.
66 FJ40 LandCruiser.
64 Chevy Van,350/350
72 Chevy 10 Van,short wb,454
78 Chevy 10 Van,short wb,350
72 Chevy Malibu 350.
77 Chevy Suburban. Silverado 20 Trailering Special.454,turbo400.
LiveWire64 is offline   Reply With Quote
Old 10-03-2010, 07:33 PM   #19
joe231
joe231's Avatar
I too have been doing some research...it seems the 5x4.75 van rotors are 1'" thick but use the same bearings as the heavier 1.25" truck rotors. So if you have the 1.25" rotors in theory you could swap to the van rotors, but I'm not sure how the 1.25" calipers will work with the narrower van rotors, or if you could use the 1' truck calipers with the 1.25" spindles....
has anyone actually done the swap?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 10-03-2010, 08:44 PM   #20
Keith Seymore
Originally Posted by 79gmcclassic View Post
nice tempest
Thank you. They are a pretty crazy little car, with the MOPAR bolt pattern, LH threads on the left side of the car, and the trans/transaxle in back.
Lots of fun, though -
K
1979-1986
1986 - 2019
Old 10-03-2010, 11:30 PM   #21
knightowl73
Yea im not sure which years but some caprices with 10 bolts late 70s thru early 80s, you can pull the axles and brake hardware from to complete it on the back for cheap. The site is on my favs someplace but a guy in washington state did it to his longbed to run camaro rallies. Ill try and find it and post it up.
Old 10-03-2010, 11:43 PM   #22
79gmcclassic
kieth i had no idea they had mopar bolt patterns
Old 10-04-2010, 04:05 PM   #23
dbmx66
me either
Old 10-04-2010, 04:35 PM   #24
Keith Seymore
me either
Yep - 5 hole, 4.5" bc.
That tripped 'em up back in the day, when they were trying to put their hot new tires and wheels on....
Dad was saying WTH?
That was after you managed to get the lug nuts loose...
(lol)
1979-1986
1986 - 2019
