Old 10-03-2010, 03:55 PM   #1
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
77 Dash Bezel vs 78 Dash Bezel?
Was curios to the different types of bezels because I'd like to get the 5 peice 78 brushed aluminum inserts and just put them on a 78 bezel and stick it on my 77...but will the 78 bezel fit? And what's the difference? All of the switches seem in the same place
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 10-03-2010, 05:18 PM   #2
sixshooter798
Desert Rat
sixshooter798's Avatar
Re: 77 Dash Bezel vs 78 Dash Bezel?
I can't think of a difference
sixshooter798 is offline   Reply With Quote
Old 10-03-2010, 06:22 PM   #3
USSkoval
The wiper hole is off slightly, maybe a 1/4 inch.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 10-04-2010, 12:16 PM   #4
THE "10" SILVERADO
I emailed Classic Parts just to get exactly the difference and modifications I would need to change out a 77 for a 78. Here is the reply
The openings in the instrument bezel are smaller on the 1978-80.
1973-77 has 4 1/2" large and 2 1/2" small gauge openings.
1978-80 has 4 1/4" large and 1 7/8" small gauge openings.
They didn't answer my question on the modifications needed to swap them out.....so does anyone know if I would be able to just screw them in the same? or will I need to replace all of the gauges so they fit the bezels?
Michael
Old 10-04-2010, 07:20 PM   #5
sixshooter798
Desert Rat
I suggest taking your original one with you to a local pic-n-pull or junkyard to see if they match up. If the headlight switch needs to be moved, its quite easy. Just drill a new hole in the metal part of the dash where you want it to go and you're done. I don't know about the wiper switch...
Old 10-04-2010, 07:38 PM   #6
USSkoval
That doesn't sound right at all... the gauges are the same size for all the years.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 10-04-2010, 07:56 PM   #7
THE "10" SILVERADO
I know that's what I wa thinking...I think the guages are the same just the bezel opening is smaller...I just want to know if I can screw the 78 on without having to change anything else
Michael
Old 10-04-2010, 09:12 PM   #8
sixshooter798
Desert Rat
If both the wiper and the headlight switches are on the dash, I don't know why you couldn't.
Old 10-04-2010, 10:40 PM   #9
THE "10" SILVERADO
Also another question...I want to get a 81-87 quartz clock for my truck (it has the 73-80 version all crapped out though) and if I were to get a lens could I just cut a hole out for the knob? Because mine has the knob in the 12 o clock and the newer ones have it at 8 o clock...so could I just get a regular lens and cut a hole out of the lens for the knob to stick through?
Michael
Old 10-05-2010, 01:54 AM   #10
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Yes you could use a normal lens. A quick way to make that hole is mark it and heat a nail up and push it through the acrylic. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 10-05-2010, 07:54 AM   #11
78 Chevyrado
I had a 78 year bezel on my 77 after somebody broke in and destroyed it stealing the radio. It worked just fine. They're just different styles as far as I know.
78 Chevyrado is offline   Reply With Quote
Old 10-05-2010, 08:14 AM   #12
THE "10" SILVERADO
Thanks, you answered in one sentence better than one of the technicians from classic parts in a few more......I don't think I have seen any pics of your 77 before....I've seen your 78 and your 81-87 yellow truck but not that one...
Michael
Old 10-05-2010, 03:28 PM   #13
78 Chevyrado
I sold the 77 back in about 2001 or 2002. it was my first one. dads "bought new" truck.
Old 10-05-2010, 07:08 PM   #14
USSkoval
^Is that the one that was originally a Sport model? Maybe I'm thinking of something else.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 10-05-2010, 07:26 PM   #15
78 Chevyrado
Yep it was a chevy sport till somebody keyed all the stripes and even if my dad could have afforded the new stripes at the time, half of them were unavailabe anyway o he peeled em all off. I remember the one lower stripe under the gas filler being like $70 or something and this was in the late 80's. so no telling what a new set would have been..
Old 10-05-2010, 07:52 PM   #16
THE "10" SILVERADO
That's nice, I remember my stepdad getting a 78 (I think) that looked exactly like that....I think the only difference was his had like a 6" lift or so...he sold it a long time ago so I barley remember anything besides pictures....
Michael
Old 10-06-2010, 05:22 PM   #17
THE "10" SILVERADO
You can put the later 78 bezel on there but it will obstruct part of the
gauges. If they are drilled out it wont look right.
I emailed them back and that was my response...I'm really getting confused because they used the same gauges from 73-80 but somehow the new bezel will make it to where I can't see the full gauge on the 77? Do they have different gauge mounts or something? I'm thinking that it will be just fine because of all of the people here vs the one technician at Classic Parts..
Michael
