Old 10-03-2010, 06:11 PM   #1
joemacho
joemacho's Avatar
vent lines in the gas tank.
please help on this and i hope its not a dumb question but i need to know if i can delete a vent line on the gas tank its the only one i dont use it s the one that comes from the vapor canister or watever its called... thanks.
1972 gmc jimmy project comin soon ( jus a sin )
1959 chevy apache shortbed fleetside (brsgrm)
1966 Chevy c30 duallie 2wd (big chief)
joemacho is offline   Reply With Quote
Old 10-03-2010, 11:52 PM   #2
71RestoRod
71RestoRod's Avatar
Re: vent lines in the gas tank.
Here's some info on the vapor tube and venting... If you're going to stub out the vent line check that you have a vented cap.
What is this goofy thing?
Fuel tank vacuum lines
What is this for?? and do i need it?
need a blazer expert
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 10-04-2010, 10:02 PM   #3
joemacho
joemacho's Avatar
thanks man so i guess i can delete the one cause my rig doesnt have a vapor canister and i never get checked for the canister either...and just use the other two for the swoshing effect so thanks again very appreciated..
