Old 10-05-2010, 04:26 PM   #1
67TexasC-10
85 k-20 Drivetrain
I have a 1985 K-20 that is lifted 6 inches with 4.10 gears and 33 inch tires...(35s in near future)
It currently has no motor trans or tcase...
Before it had a pretty stock 350 with an sm465 and an np205 i believe...
I know have a 350 out of a nova than ran 11s to put in it... it is backed by a 2wd turbo 350.... minus the fact of no 4wd what would it be like to have that setup in this truck....? It is going to be a daily driver that will tow the occasional trailer of up to 5000 lbs? And do some moderate mudding and trail ride as well as pullin people out... Shuld i switch back to an sm465... an nv4500? what transfercase should i use? np205? Has anyone ever used a gearvendors unit on either transmission? I would like to get it goin as fast and cheap as possible! Also oklahoma to Texas drives will be made often!
Thanks-Blake
67TexasC-10 is offline   Reply With Quote
Old 10-05-2010, 05:02 PM   #2
82swampthing
82swampthing's Avatar
Re: 85 k-20 Drivetrain
If your going to be towing,muddin and pullin people out ,I'd go with the
nv4500 over the sm465 for the overdrive and the np 205.
R.I.P gm 1908-1986
1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f
82swampthing is offline   Reply With Quote
Old 10-05-2010, 05:04 PM   #3
67TexasC-10
what about the difference in the low gear ratio?
Old 10-05-2010, 05:26 PM   #4
82swampthing
In the transmissions?In the nv4500 low or first was 6.34:1 in the 92-94 and the 95 and up ones have a 5.61:1.the sm 465 has a 6.55 first.There both great transmissions just the nv4500 has overdrive and a little bit higher low
R.I.P gm 1908-1986
Old 10-05-2010, 05:30 PM   #5
67TexasC-10
will it fit with the same driveshafts? bellhousing? etc?
Old 10-05-2010, 05:30 PM   #6
82swampthing
also if you wanted to you can compare the sm465 and the nv 4500 against each other at this site http://www.grimmjeeper.com/gears.html and you can see what your truck will be running at different rpms and speeds.
R.I.P gm 1908-1986
Old 10-05-2010, 05:39 PM   #7
82swampthing
I would do a search on here cause I'm sure somebody has done a nv4500 np 205 swap.
R.I.P gm 1908-1986
Old 10-05-2010, 05:40 PM   #8
67TexasC-10
Thanks...what is a good year for the nv4500?
Old 10-05-2010, 05:59 PM   #9
82swampthing
most people say the 92-94 are the best because of the lower first ,but are hard to find.I would search on here and see what other people are using and what the differences are.
R.I.P gm 1908-1986
