Old 09-29-2010, 10:16 PM   #1
cheepin
Question 1987 Suburban TBI not running right.
So my 87 Sub has been hesitating when at partial throttle or when climbing hills.It doesn't do it all the time most of the time when it does it is like it isn't getting gas for a sec.Other times it backfires through the TBI.
I changed the fuel filter and the fuel pump is a GM one that is like 5yrs old.I did the carb cleaner trick and found the base gasket was leaking air in.Replaced it.
It is not throwing any codes.I was thinking Mas sensor or TPS.I don't just want to throw parts at it.Thanks in advance.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 09-30-2010, 04:43 AM   #2
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Re: 1987 Suburban TBI not running right.
try replacing the spark plugs and wires they can make a car hesitate some
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 10-05-2010, 10:52 PM   #3
cheepin
So no one else has any ideas.It acts like a bad accel pump on a carb.One other thing is it revs up fine when on the gas.It is only when at partial throttle.
