Old 10-06-2010, 09:53 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Another V8 question
You need to figure what gearing you have.
Off the top of my head, I can't remember if that would be a 4.10 or a 4.56 gear. if it is a dual rear wheel truck, it's a 5.13.
I would seriously consider getting a later model 14 bolt rear with a 3.73 or so gear ratio. The engine can pull plenty. And most likely, you aren't even hauling/pulling the major weight the truck was built for anyways.
A smaller engine would help, but not as much as better gearing. Regardless of the engine, you'll still be reving 3000+ RPMs on the road, and still getting passed by socker moms left and right.
Old 10-07-2010, 12:33 AM   #2
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Right on. I had a '63 (maybe it was a '65) back in about '83. It was a half-ton stepper with a 4-speed granny 1st. I changed the carb, coil, distributor, plugs, and almost everything that "screwed" that was engine related.
On a good day, I got nine.
But it could climb mountains.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
