View Poll Results: Will I have problems? | |||
Yes | 0 | 0% | |
No | 4 | 100.00% | |
Voters: 4. You may not vote on this poll |
06-06-2003, 09:35 PM | #1 |
Are my tires too big for this drop?
I am going to drop my chevy with 2 1/2 drop spindles in the front with new shocks and 4 inch rear drop spings, lowered shocks. My tires are 235/75/15. Am I going to have any problems?
I am also buying shock relocaters for the rear, new spring retainers, and an ajustable track bar. here is a link to some before shots. http://67-72chevytrucks.com/vboard/s...threadid=54971 Thanks for your help!
72 C10 SWB 02 Subaru WRX 95 Nissan 240SX |
06-06-2003, 09:47 PM | #2 |
shouldn't be too big. should look just right with a 2/4 drop. truck definitely looks good.
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
06-09-2003, 09:56 AM | #3 |
Dreaminator
Your wheels should not be a problem. Just check the lower A frame fit if your rims are more than 8.5 inches. I am having some problems with my Panard bar in the rear after using 4 inch dropped springs on a 1971 Lwb. I would be interested in how you or others layed out the geometry of bar from the rear housing.
The Dreaminator Daily Driver 1971 Cheyenne 10 Lwb Tilt/Tac 402 .030 TH400. |
06-09-2003, 09:36 PM | #4 |
I bought an adjustable bar for about 65 bucks from, good deal.
New and used Truck parts Athey's Classic Truck Parts Front Royal, Va. www.s-c-t-p.com oldtruck@shentel.net
06-11-2003, 04:49 PM | #5 |
Old Skool Club
I am running ECE's adjustable track bar on the rear of my '69 SWB, with a 4-inch drop, via springs. The rear end is centered in the chassis. When I had it aligned, we went with factory settings, even though the front was dropped 2.5-inches with spindles. Only mitigating factor was a change to 7-inch wheels from the 8-inch width....disc brakes add width to the track, compared to drums.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
06-11-2003, 09:25 PM | #6 |
ChevLoRay-
Do you have a pic of your truck? What size tires are you running?
