10-07-2010, 02:20 AM | #1 |
i still can not get the door to close
so i put new weather striping on and i can not get the door to close. i have to slam the door. i have play around with the door. move it around alot. any ideals?? i am thinking of making the door slits longer so the door can move the door out more.
10-07-2010, 06:08 AM | #2 |
"Where were you in '62?"
Re: i still can not get the door to close
Think it will have to take a while to break in.
Make shape and form to your door. After a while if it's still hard to close you might have to adjust the door hinges etc.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
10-07-2010, 06:22 AM | #3 |
and a few others
new weatherstripping always does that. It just takes a while.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
10-07-2010, 10:44 AM | #4 |
I have actually taken a ratchet strap and used it to pull the doors in tight to "smush" the seals in some. Works best on a hot, sunny day though. Time will help, but the strap works if you can leave it on a few days.
Slowly but surely getting it done. |
10-07-2010, 02:30 PM | #5 |
Use a hairdryer to soften the stripping and close the door a few times so it will take a set.
10-07-2010, 05:39 PM | #6 |
Someone correct me if I am wrong (which I am sometimes), but aren't you supposed to either "V" the ends of the weatherstripping (where the two ends meet at the bottom) or put small holes in it so the air can escape from within the rubber when you close the door?
My truck does not have door weatherstripping at the moment so I can not look at mine. |
10-07-2010, 06:57 PM | #7 |
you may need new door pins.
the bushings and then the pins themselves get worn out over time. -W |
