Closed Thread
Old 10-07-2010, 07:39 PM   #1901
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: What did you do to your truck today?
Got the cig lighter working today. I know its not a big deal, but sometimes its the little things..
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 10-07-2010, 07:51 PM   #1902
Cops053
Cops053's Avatar
Now that the bed is off, I cleaned, scraped the exposed frame, pulled the rear tires off and repainted the frame area. Going to start cutting the wood for the bed floor tomorrow and dry fitting it before drilling all the required holes. Then stain followed by multiple coats of marine varnish.
Cops053 is offline
Old 10-07-2010, 10:09 PM   #1903
nachodog2
Hell yeah!!!
nachodog2's Avatar
I started setting in my air shocks with the new brackets that I made myself.
Stock is good but custom is the sh*t!
nachodog2 is offline
Old 10-08-2010, 01:16 AM   #1904
mr andrerson
Originally Posted by chevy_mike
Monday evening I put my valve covers and air cleaner on.
YES!!! Love those air cleaners! The valve covers look pretty sic too.
__________________X2!!!
mr andrerson is offline
Old 10-08-2010, 06:54 PM   #1905
lakeroadster
Finished up installing the treated plywood in the bed. More details in my build thread....
lakeroadster is offline
Old 10-08-2010, 07:34 PM   #1906
1/2Dozen
1/2Dozen's Avatar
I picked this truck up a few weeks back, it had a few wiring issues that I managed to get solved with help from a few others on here. Installed a better fuse panel then what I had, thanks too Gulffishin!
The white pic is what it looked like when I picked it up but I had to paint it black. I plan on a candy apple red over a gold base with silver flake and a white pinstripe to seperate the black from red like my motorcycle.
66 suburban
51 Merc 2 door coupe
38 Chevy Business Coupe (gf's)
76 Airstream Sovereign
1/2Dozen is offline
Old 10-08-2010, 07:36 PM   #1907
1/2Dozen
1/2Dozen's Avatar
Oh, and the black pics were taken today. First pics!
66 suburban
1/2Dozen is offline
Old 10-08-2010, 07:51 PM   #1908
Cops053
Cops053's Avatar
not a darn thing........day off.but wife had me take care of her growing honey-do list....ohh well.one has to do what one has to do for the honey
Cops053 is offline
Old 10-08-2010, 09:23 PM   #1909
markeb01
Senior Enthusiast
markeb01's Avatar
It turned out great. The bodywork looks really straight. What type paint did you use?
markeb01 is offline
Old 10-08-2010, 09:28 PM   #1910
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Last night I test fitted the new Mar-K TG. Very nice product!!
Alan's Classic is offline
Old 10-08-2010, 09:47 PM   #1911
1/2Dozen
1/2Dozen's Avatar
[QUOTE=markeb01;4231165]It turned out great. The bodywork looks really straight. What type paint did you use?[/QUOTE
the cab and front clip were in pretty good shape to begin with no rust on the truck anywhere. The box was the worst part of it and had very minimal mud in it. All I did was scuff it up and paint it.
this was my second time using tractor implement paint but learned from the last time to thin it down more then the actual recommended rate. I sprayed the 65 with 1 gallon paint/32 oz thinner and did 3 coats and used a base coat style spray tip. The rate they recommended was 1 gallon paint/16 oz of thinner and i sprayed it with a primer style gun. It looked decent in pictures but dried sorta grainy i guess. Here is a pic of the 61 I first used implement paint on.
66 suburban
1/2Dozen is offline
Old 10-09-2010, 01:08 PM   #1912
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
I actually got to see my truck the other day! First time in ten months or so, now I'm back to 6000 miles away from it....
Ghostwhite is offline
Old 10-09-2010, 05:21 PM   #1913
63sbssbbw
UCA63
63sbssbbw's Avatar
Welcome Home GW
Today I sandblasted primed and painted my rear axle
Tomorrow, bolt it in and its a roller......finally!
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline
Old 10-09-2010, 06:53 PM   #1914
CVA59
same here, painted, painted and painted some more.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline
Old 10-10-2010, 06:47 AM   #1915
skysoldier173rd
skysoldier173rd's Avatar
Installed a cable type gas pedal out of a 90 in my 60. Was relatively easy, and a big improvement. works great, easy to adjust. Just had to bend the pivot rod to match the 60 and drill a few holes. A good improvement and well worth the time.
skysoldier173rd is offline
Old 10-10-2010, 11:13 PM   #1916
enick72
enick72's Avatar
Yesterday I pulled my (knocking) engine and trans from the 65 and pulled an engine from a 78 doner truck. Today I got the needed parts swapped over along with adding a T5 and dropped in and bolted up. Tomorrow night should be able to get it all wired up and running. I will have to wait to drive since I have to measure for my new drive shaft.
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline
Old 10-11-2010, 07:52 PM   #1917
Cops053
Cops053's Avatar
Spent yesterday and today after work cutting and fitting the Ash boards for the bed, ordered the bed bolt kit, so decided while waiting for them to arrive made a template of the bow tie to route out the wood on the 3 rd board in from each side and going to insert a piece of black walnut into each center betwween the stainless strips and the rear two bolts.
Cops053 is offline
Old 10-11-2010, 09:17 PM   #1918
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Well, ended up adjusting the door striker... because I had to, not wanted to...
So here's the story. I put some Dodge Dakota door seals on the driver side, as many had said they work well. Picked them up this weekend at the junk yard. After installing them, I almost could not get the door to close they were so tight. Let the sit in the heat the last couple days but no better. Can't even get the door to close all the way from inside the cab.
Today I decided to remove them. Now there are no seals. Well that's where my problem started. I closed the door and could not get it to open, no matter how hard I pulled. Crawled thru the window to open the other side (no outside lock) and proceeded to remove the door panel. Worked on trying to get the latch to rotate and release the door. No luck. With the wife pulling on the door, I used a prybar to carefully push the door up, thinking it was hanging on the striker. Sure enough the door opened. Verified this was the issue by repeating it again.
Adjusted the striker down and it works as it should. Put a piece of cut off Dakota seal near the striker and now it latch with a solid feel and sit flush with the body. That works until I buy new seals. Man, some times it just doesn't pay to fix something that's not broken...
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Old 10-11-2010, 09:28 PM   #1919
64GMCHorsepower
Justified!
Found out why none of my rear lights worked finally.....I had grounded the lights to the bed....well, I remembered around lunch today that HEY! The bed sits on rubber pads..so I moved the ground to the frame rail, and voila'....lights!!!!!!
Also finished installing my new Rebel Wire Harness......
She's ready to drive to work tomorrow!
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline
Old 10-12-2010, 06:35 PM   #1920
66GMC-Canuck
66GMC-Canuck's Avatar
I gassed mine up and then hauled a whole bunch of junk to the dump. Just nice to be out driving.
66 GMC 1500 Series LWB
66GMC-Canuck is offline
Old 10-12-2010, 08:38 PM   #1921
karlbenz
shot some primer on mine.
karlbenz is offline
Old 10-12-2010, 10:40 PM   #1922
willyp
willyp's Avatar
got alot done this weekend with the help of my dad. the wife has the camera on a road trip but dad got some good pics of my new wheels and tires. also new bumpers and 66 NC truck plate. more pics thursday when the OL gets home.
The price of cool aint cheap.
willyp is offline
Old 10-13-2010, 04:32 AM   #1923
old cruiser
old cruiser's Avatar
Started reassembly of the 230 all like new again out 0.030
And painted engine bay, may get this o the road yet
old cruiser is offline
Old 10-13-2010, 08:50 AM   #1924
lakeroadster
Fabricated some caster support brackets for my stepside bed. This allows positioning the bed without using my engine hoist.
Makes moving it in and out of my work bay much easier.
Old 10-13-2010, 07:36 PM   #1925
markeb01
Senior Enthusiast
markeb01's Avatar
Several years ago I upgraded from a Hurst Competition Plus shifter to a Street Super Shifter. The higher mounting and straight rods make the shifter work much nicer, but it also moves the shifter head back several inches which I haven’t been all that happy with. It finally occurred to me a simple adapter could be fabricated to move the shifter handle and also angle it forward at the same time. I worked up a template and transferred the dimensions to a chunk of scrap steel plate. The bottom of the stick moved forward 1 ¼”, while the knob moved forward about 2”, putting it in a much more comfortable position.
Update -
After driving it for a day I realized the knob was a tad too far forward in 3rd gear. Since the adapter raised the stick almost an inch, I went back to the shorter stick and reset the angle about ½” to the rear. While I had the adapter apart, I also cut the upper rear corner off. Although nobody else will ever see it, I thought it looked crappy so a cosmetic improvement was in order. Now all 4 gears are within perfect reach:
markeb01 is offline
Closed Thread
