Old 10-07-2010, 09:40 PM   #1
saskgreen
saskgreen's Avatar
Re: 3 Speed Bolt out Swap for M20
I just crawled underneath and it is a 4 bolt. I did a measure and she is about 21 inches so I guess I am in luck, however I will still need either that spacer ring, or a 67 bell housing, as my truck is a 70. Thanks for the info. Muchly appreciated.
saskgreen is offline   Reply With Quote
Old 10-08-2010, 02:45 AM   #2
raycow
Saskgreen, the good news is, you may not have to buy a spacer ring.
All the 4 bolt transmissions I have seen had the small size bearing retainer, and they wouldn't have come stock in a 70, so I think you are looking at a transmission swap done by the PO. If he did his homework, he would have used a spacer ring, or else swapped an earlier bellhousing. Either way, you are good to go with the Muncie.
Worst case, the PO ignored the center hole mismatch and just bolted the early transmission to the 70 bellhousing without a spacer ring. In that case it would still run, but not for very long. Is the 3 speed dead now, or does it still drive ok?
Ray
raycow is offline   Reply With Quote
