Old 08-05-2010, 03:41 PM   #1
jjames
3 Speed Bolt out Swap for M20
Hey all - I've looked and searched alot, but havn't found the answer to the following.
Last week I blew out the stock 3speed in my '71 long bed.
The truck has a 350 in it and I am looking for a bolt in replacement 4speed (M20).
My question is, what do i need to get? Input shaft splines? output shaft?
What else do I need to know? What do I need to order?
Thanks!!!!
James
jjames is offline   Reply With Quote
Old 08-05-2010, 08:24 PM   #2
jjames
Re: 3 Speed Bolt out Swap for M20
here is a pic of the truck i am working with
Old 08-05-2010, 10:18 PM   #3
raycow
You have a 10 spline input and 27 spline output. A Saginaw 4 speed would be a direct replacment, but if your Sag 3 speed didn't die from natural causes, you will very likely grenade the Sag 4 speed too.
This means you want something stronger, like a Muncie or T-10. If you don't want to replace your clutch disc or driveshaft yoke, I think that pretty much limits you to a Muncie from about 63-70. Later ones than that were 26 spline input and 32 spline output.
As for the T-10 and ST-10, I think that spline combination might be kind of scarce. The early ones (up to 63) were 10/16 and the later ones (after 74) were 26/32. These are GM original equipment units. I think the 10/27 combination might have been used for aftermarket, but I'm not real certain about the non-OEM stuff.
Ray
raycow is offline   Reply With Quote
Old 08-05-2010, 10:33 PM   #4
jjames
Ray - thank you for the info. Just what I was looking for.
I agree about the Saginaw - the 350 is putting out around 325 and it ate up that 3 speed with very little abuse.
As for changing out the slip yoke and / or clutch pack, i am fine with either or both, - its just a matter of not knowing what I don't know right now.
I was looking at putting in a rebuilt M20, but most everything I come across is 26In / 32Out - (ie this) and I am unsure what changes are needed to handle that.
I guess to put it plainly - if i wanted to put in a new / rebuilt M20 (or M22) and I was currently running the Sig 3 speed, what all parts am I looking at?
  • The new trans (lets assume is a 26/32)
  • New shifter (Hurst universal?)
  • New cluch pack (11 or 10 inche?) with the 26 spline inner gear / hub
  • New 32 spline slip yoke
  • New or shortend drive shaft?
  • others??
Old 08-06-2010, 12:11 AM   #5
geezer#99
geezer#99's Avatar
Shifter sits farther back on the tranny too. Might need to notch your seat or use bucket seats.
And get a good Hurst shifter. The universal ones won't handle a lot of crap.
Old 08-06-2010, 12:40 AM   #6
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
I put an M20 in my 68 behind the 6 cylinder. Hurst shifter works great. I do have a mid 90's Chevy split bench in it. I had to shorten the drive shaft and get a longer speedo cable.
low'n slow is offline   Reply With Quote
Old 08-06-2010, 05:37 AM   #7
raycow
You pretty much got it all right there. The 32 spline transmissions are slightly longer than the 27 spline. I would say put the new yoke on your present shaft and try to install it. As long as you have at least 3/4" before bottoming out the yoke (at ride height) you should be ok. If anything less than that, you need to get the driveshaft shortened.
If you can't find a truck-specific shifter, Hurst makes one for 55-57 Chev cars that will clear the truck bench quite nicely.
Ray
Old 08-06-2010, 12:10 PM   #8
jjames
thoughts on the drive shaft? Will i be okay with the stock on or have to get it shortened?
Old 08-06-2010, 01:12 PM   #9
raycow
Well, that's what I don't know. I suggest that you try it unaltered first. Just swap the yokes and see now much free travel it has. If there is at least 3/4" I would say you are good.
Ray
Old 08-07-2010, 01:21 AM   #10
67ss&99ss
Andy
I'm not sure about the driveshaft, but you will love the M20. I have one in my 67 Camaro with a 3.73 gear and it has took all of the abuse my 406 can give. I highly recommend that you have the flywheel and pressure plate balanced. When I converted my car to a 4 speed I didn't have it balanced. When I pulled my 350 and put the 406 in, I had it balanced and the difference was amazing. I had a vibration through the shifter that was pretty bad over 3500 rpm before, and now that its balanced, the vibration is completely gone. Well worth the money in my opinion.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 08-07-2010, 10:08 AM   #11
jjames
Well right now I have a line on a factory 64-65 GM Muncie M20 wide ratio with Hurst high performance Competition Plus unit.
Its a 10/27 spline unit, so hopefully will be a direct bolt in and I might only have to deal with a shortened drive shaft (and there is a great machine shop here locally that does them).
Fingers crossed!
Old 08-09-2010, 11:08 PM   #12
jjames
Well - good news and bad. I didn't get the M20 listed above - but I did get a brand new rebuilt from www.KajunJon.com.
Tonight I pulled the drive shaft and 3 speed out (again) and will hopefully have the new M20 shipped out tomorrow.
Old 08-09-2010, 11:31 PM   #13
jjames
perhaps the worst movie - ever - but here is the old 3 speed with the side cover off - best I can tell while driving it - its a bad shaft bearing, but...
Old 08-10-2010, 12:32 AM   #14
71 super
71 super's Avatar
Def. get a competition plus hurst and immediately upgrade the bushings that come with it to the bronze sintered type (the plastic crap will not last and makes the shifter sloppy) the bronze will tighten it up nicely. you may also need to tweek the throws a little to shorten them but this is a great shifter to play with. In a former life I had a m22 wth the comp plus and a centerforce clutch behind a health 355 with a tunnel ram and drive shafts and rear yokes became a problem after a while- but I was young and it was fun, out one night spend a week making enough money to buy parts and go play again.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 08-10-2010, 06:28 AM   #15
rsavage
rsavage's Avatar
Several years ago I replaced the non synchro first 3 speed in my 66 with an M20 which was a 10/27 spline. I think it was a 69 transmission. I bought a Hurst competition Plus shifter that was supposed to work for trucks, but the handle had to be cut and rewelded at the base to clear the bench. Even now it is up against the bottom of the seat in 2nd and 4th. Obviously the 3 speed floor shifter hole in the floor isn't going to line up with the 4 speed as the shifter is on the rear of the tranny. If I recall correctly, driveshaft was real close. See if you can get a 27 spline yoke that is about the same length as your 3 speed yoke.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 08-10-2010, 10:57 AM   #16
raycow
What kind of shifter is that on the Saginaw? I like the way you can move it along the mounting bracket.
Ray
Old 08-10-2010, 11:13 AM   #17
geezer#99
geezer#99's Avatar
Looks like mine Ray. Mr. Gasket or Hurst Indy. You can move them on the bracket or drill new holes for optimum positioning.
Sorry. Don't mean to highjack JJAMES.
Old 08-10-2010, 11:25 AM   #18
no moa
no moa's Avatar
Guy i work with had a 69, 396 LB. Put the saginaw in it, and used the 3 on the tree column shifter. Had a rod beside the seat he used for reverse. It was really neat. I remember he got it stuck between 2 and reverse one day.
no moa is offline   Reply With Quote
Old 08-10-2010, 12:53 PM   #19
raycow
That's pretty neat. Thank you.
Ray
Old 10-06-2010, 09:04 PM   #20
saskgreen
saskgreen's Avatar
So if you get the 63-70 Muncie, the 10/27, is it a direct swap for the original 3 onthe tree? Or will I need to get a different bell housing or driveshaft lenght? Thanks for any input on this, for I will be tackling this next spring, but getting the parts together now.
saskgreen is offline   Reply With Quote
Old 10-06-2010, 09:49 PM   #21
raycow
If your bellhousing is 67 or earlier, just bolt the Muncie on. 68 or later will need a spacer ring like this.
http://dennymac.com/mod.php?mod=user...103&page_id=54
Your driveshaft will work as-is if your 3 speed has a 7 bolt side cover. If it has a 4 bolt cover, measure from the bellhousing face to the rear seal. You are hoping for ~ 21". If it is closer to ~ 16", you will need to shorten the shaft. There is also a 9 bolt cover, but they are EXTREMELY scarce. If you have one of those it isn't practical to modify the stock shaft to work with the Muncie, so you will need to get a replacement.
Ray
Old 10-07-2010, 09:40 PM   #22
saskgreen
saskgreen's Avatar
I just crawled underneath and it is a 4 bolt. I did a measure and she is about 21 inches so I guess I am in luck, however I will still need either that spacer ring, or a 67 bell housing, as my truck is a 70. Thanks for the info. Muchly appreciated.
Old 10-08-2010, 02:45 AM   #23
raycow
Saskgreen, the good news is, you may not have to buy a spacer ring.
All the 4 bolt transmissions I have seen had the small size bearing retainer, and they wouldn't have come stock in a 70, so I think you are looking at a transmission swap done by the PO. If he did his homework, he would have used a spacer ring, or else swapped an earlier bellhousing. Either way, you are good to go with the Muncie.
Worst case, the PO ignored the center hole mismatch and just bolted the early transmission to the 70 bellhousing without a spacer ring. In that case it would still run, but not for very long. Is the 3 speed dead now, or does it still drive ok?
Ray
Old 10-08-2010, 08:30 PM   #24
saskgreen
saskgreen's Avatar
Actually the 3 speed runs and shifts just fine. I am switching it out because I am putting a 350 in it that will be pushing 375-400 horse, and wanted a tranny that will take it. I have heard nothing but good things about the muncie. But this is good news, perhaps at one point in the trucks life the original 3 speed failed and they put a different one in, who really knows lol.
Is there any numbers on the bell housing that I could look for that would indicate the earlier bell housing?
I had a someone drive the truck who has had many of these old trucks, and he said it shifts like a dream haha worse comes to worse I will have to switch out the bell housing I guess.
Old 10-08-2010, 10:28 PM   #25
raycow
3815891 should be a good casting number for the small hole, but I believe there are others that will work. Unfortunately, the number will be covered when the transmission is bolted on. Once you get the transmission off, it will be just as easy to measure the hole directly.
Ray
