Old 10-09-2010, 06:58 AM   #1
48cj2a
48cj2a's Avatar
Re: Slow moving '79 1 ton project
Originally Posted by jonvo4591 View Post
I'm not sure what could cure such a problem short from new springs, which are in the plans
Another option is to remove every other sping after the main and second spring. Go to the part store and get new spring center pins.You may be able to reuse your ubolts if you can wire brush the threads and soak them with penetrant.
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 10-09-2010, 11:01 AM   #2
jonvo4591
jonvo4591's Avatar
I will have to check into that removing some springs.
I'm not sure how well that would work because then I have a feeling my springs would end up like 6 inches shorter and the threads on my u bolts might not go up that far on the bolt.
I didn't really want to mess around with disassembling the leaf packs, but It is an option to be considered, since It can be done for almost free.
I'm gonna see what I can do today as far as the gas door and wheel cutouts go.
1.) Good
2.) Fast
3.) Cheap
Pick two.
jonvo4591 is offline   Reply With Quote
