Old 10-10-2010, 02:53 PM   #1
CollinH
Heads
I am looking for a good set of heads for my 327 i am building but i dont know much of what to look for, any ideas?
CollinH is offline   Reply With Quote
Old 10-10-2010, 02:55 PM   #2
gearys 5600
gearys 5600's Avatar
Re: Heads
The later model (1996-2000) chevy vortec haeds are hard to beat for the money.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 10-10-2010, 05:16 PM   #3
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Heads
I agree with the above on the vortecs, but remember that it takes a different intake manifold which is generally more expensive. And with the cash for clunker program the vortecs heads have become harder to find. Depends on how much your willing to spend and what kind of performance you're after. There are a lot of good aftermarket heads, there are good older original heads but they will need work, like hardened exhaust valve seats, a valve job (which is not cheap anymore) and if you find small chamber heads for higher compression, you might want to have them ground for larger valves so there is that cost plus the new valves. You can spend a lot on heads if you want, and that is where most of the hp potential is found.
hgs_notes is offline   Reply With Quote
Old 10-10-2010, 06:07 PM   #4
llowlife
Re: Heads
By the time you rework stock heads you might be able to find a good set of aftermarket heads. How much do you want to spend and do you want to go aluminum or CI. I have a set of ported World S/Rs on my 388 with the 1.94 and 1.5 valves that are around 170cc runner volume and they have some very impressive flow numbers and the low end torque is amazing with the 170cc runners and the upper limit is 5700. These heads were very cheap because they were overlooked and poo pooed as boring lack luster heads...So don't overlook stuff because someone says it "bad"
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot.
I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace...
72 short step w/ 388 /4l80e/ and 3.08 gears.
llowlife is offline   Reply With Quote
Old 10-10-2010, 11:22 PM   #5
CollinH
Re: Heads
ok thanks for all the info
Old 10-11-2010, 08:57 AM   #6
jamesi20
jamesi20's Avatar
Re: Heads
take a look at these from summit. a lot of bang for the buck.
http://www.summitracing.com/parts/WR...ize|5.4L%2f327
jamesi20 is offline   Reply With Quote
Old 10-11-2010, 03:14 PM   #7
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Heads
This is a great deal here
http://www.summitracing.com/parts/CM...ComboContents/
